Old 12-01-2006, 02:02 PM
pfarber is on a distinguished road
Best type of quick connectors for motors?
A lot of controller boards uses simply screw terminals for connections. Then most seem to put a fancy MOLEX - type connector on the side of a project box.
Whats the best way / type of connector for securing motor cables to the controller enclosure and still be easy to remove? Ie reuqire no tools.
Thanks.
Old 12-01-2006, 02:10 PM
Al_The_Man's Avatar
I would say a cheap efficient way is the AMP CPC (circular Plastic Connectors) line.
The are close in appearance to the MS Military style metal connector but much cheaper. 1/2 turn removal.
Old 12-01-2006, 02:16 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
I used the CPC connectors for nearly everything on my controller. They are OK, but they are not all that robust. I haven't had connection issues but several of the 90 degree backshells have been broken in the last few months just from handling the cable bundle during clean-up activities.
I have an entire list of connector links I was trying to post, but I can not post links right now for some reason...... ?
I purchased the CPC connectors from Mouser electronics. If I recall, they had better pricing than Allied.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 12-01-2006, 05:26 PM
smarbaga is on a distinguished road
i was thinking along the line of xlr connectors.
just wondering if anyone uses them, and has any comments on them.
also jones type of connectors, (the square ones) and the same question as above.
i would think for small signal cables the db connectors would suffice.
i would also think that some kind of conductive/anti-corrosive/dust resistive/moister repellant grease would be a good idea,(there's a mouth full)
not pritty but practicle.
Old 12-29-2006, 01:50 PM
cncuser1 is on a distinguished road
could you post a link to these please?
Old 12-29-2006, 01:51 PM
Scott
Could you try again and post the links , thanks
Old 12-29-2006, 01:53 PM
Can you post a link to these connectors, I'd like to get a better idea about what is appropriate, what size motors are they connected to?
Old 12-29-2006, 08:59 PM
rkd rkd is offline
rkd is on a distinguished road
I just bought several of the XLR cable connectors and some chassis jacks. I am going to be wiring them up in the next little while here.
http://www.neutrik.com/content/produ...tMSDE_industry
Old 12-29-2006, 09:12 PM
ViperTX is on a distinguished road
You need to pay attention to the current rating per pin of whatever connector you use.
http://www.switchcraft.com/products/...or-search.html
http://catalog.tycoelectronics.com/T...0572&LG=1&I=13
Old 12-29-2006, 09:22 PM
Al_The_Man's Avatar
Go to Tycoelectronics.com and do a search for CPC.
  #11   Ban this user!
Old 12-29-2006, 09:28 PM
Thanks for thhe responses, they are a grat starting point for us people who need a bit of help
  #12   Ban this user!
Old 12-30-2006, 01:55 AM
another connector to consider would be the cinch jones
for motor power and multi line connections.
they are not as prity but i see them in a lot of industrial
equipment, whereas the xlr show up mostly in audio stuff.
i think both types of connectors are electronically and mechanically
equal in there connection proporyies.
the cinch jones having more pins and being able to handle more current.
i would use some connector grease if i were to use either one.
http://www.action-electronics.com/cinch.htm
