Old 01-27-2004, 02:05 AM
Hobbiest is on a distinguished road
router speed regulator
anybody ever used a light dimmer switch to control router speed? any electritians out there know if it would work? Seems like lower voltage would make it spin slower.
Old 01-27-2004, 05:08 AM
peterklos is on a distinguished road
Unless you have a very low powered router a dimmer speed control wont deliver the amount of current required to run the router. Routers have high start up currents and most dimmer controls have low wattage components .
Try a mains motor controler of around 5 amps to control the router , a kit was released in silicon chip magazine oct 2002 which would do the trick
Peter
Old 01-27-2004, 09:38 AM
pack rat is on a distinguished road
When you use light dimmer the power goes from low to high whereas motor goes from high to low. I dont think it is good for the motor. I read somwhere here that you can buy motor speed controller for $10 on sale from Harbour freight, otherwise is $20.
Old 01-27-2004, 02:12 PM
Zephrant is on a distinguished road
Buy a real router speed control like this:
Rockler
Even a 5 amp dimmer is not enough. A 3hp Router would need at least a 15 amp speed control. The above unit is good to 20 amps.
Zeph
Old 01-27-2004, 04:36 PM
Thanks guys, knew someone knew the answer!
Stop talking about it and do it already!!!!!
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 07:01 PM
Finding The Right Router Crushmonkey Commercial CNC Wood Routers 22 06-19-2006 01:17 AM
Quick built router CNC Darren DIY-CNC Router Table Machines 10 06-05-2005 08:09 PM
S/S Relays and Variable Speed Routers InventIt General Electronics Discussion 1 08-24-2004 12:05 PM
Spindle Speed & Feed Rates - Question Moondog DIY-CNC Router Table Machines 1 07-23-2004 06:24 PM
