Ok i will be setting up some 90volt servo's to some g320's I was thinking of rewinding a microwave xformer, basically i'd like to do 80 volt 30 amp lotta va lol......My question is this what gauge should i use to rewind and what output voltage do i want on the transformer to hit lets say 79.9 volts dc after caps? i'm going to parallel a bunch of caps what final cap value should i be looking at? going to use 100v rated caps and a 100v rectifier, is that too low should i be rating caps and rectifier higher? thanks |
| elogicca, The gage of wire will depend not only on the current rating, but also on the allowable temp. rating of the wire and what you expect to have when in service. I used to have a bookmark on an excellent site for wire sizing, but haven't been able to find it yet.(will report back here when I find it:}) Please realize that as wire size goes up, so does the cost --drastically and the bigger the wire, the harder it is to work. For output voltage of the transformer you would be looking at 61-62VAC and I personally would use at least 200V rated bridge and for caps IIRC, you need at least 150% rated for them. When I make my transformers, I wind to what I think I need and then carefully hook it up and measure the voltage. If to high, remove a turn or so and if to low, add untill I achieve the desired results. My first question is, "Do you REALLY need 30 amps?" . Based on formulas provded by MR GECKO, Watts = IPM * Lbs / 531 and on my mill/drill, it works out that I am using less than 3 amps per servo at a 500# load! Even if I am running all 4 axis at max simutaneously, that is still only 12 amps! As for size of the Cap, again from MR GECKO, Size µF=80000*I/V where I is maximum current and V is the DC voltage. So in your case of 80V and 30 amp it would be about 30,000µF! Thats a lot of cap!!!!!! I guess what I am saying, is be sure of the values you NEED, and not guess at them. As Volts and Amps go up, so does the cost---exponetially:})
__________________ Art AKA Country Bubba (Older Than Dirt) |
| The servo's i'm looking at have a terminal voltage of 90volts and a continious current of 7.6 amp with a peak current of 38 amp, so i figured if all 3 axis are going i need 22.8 amps, add some overhead and thats how i got 30 amps... these were the servo's i was looking at http://www.kelinginc.net/KL34-150-90.pdf am i corrent on my thoughts, persoanlly less amps would be better as the wire thinkness and cap ratings...... Thanks |
| Again I refer to Mr. Gecko who indicated a good design parameter was to design to 66% of your total demand or about 20 Amps in this case. If you use geckos, you can't exceed the limits of 20 amps per drive anyhow. Also, I don't think your application will be running at anywhere max all the time anyhow! Again, I relate to the forces needed to do the job. Think about the fact that your car has an engine that will develop several hundred horsepower, but I doubt that you run it at max all the time. Look at the watts required to drive the load. IF you are running 80V at a current of 7.6 amps, that is = to about 600 Watts. OK, IF you are running at say 20 IPM that is a cutting force of over 16,000 lbs!!!! if I have done the math correctly. I THINK that if you try to apply 16,000 lbs of force on any of our "hobby" machines, then something is going to BREAK (hope you don't get hurt) Just some food for thought!
| Thankis Bubba I think i wrapped my head around it all, also saw some of your posts where you can include different windings for other voltages, cool ![]() I'm going to try and locate some enamel winding wire tomorrow i guess 8awg for @20 amps? Thanks |
| Depending on which refrence you look at, you will be looking at 750 - 1000 CM (Circular Mills) per amp. I have a couple of sources that I use depending on wire size. For up to 12 AWG, I generally use WWW.mpja.com or www.surplussales.com as they also have large sizes. Depends on how much you need! Sorry, I have no Canadian suppliers.
| Yep Canada sucks for getting stuff, lol do you think i could braid 2x16awg for a total of 20 amps??? found it locally. I guess i could use 21 for my 5/12 volt coils now just gotta convert lb's into feet cause it's sold by the pound. |
| Once you get into the larger sizes it is easier if you can come by the square section wire, but harder to get. Alternatively, wind bifilar, this is winding two smaller conductors together side by side, and paralleling them. Al.
#10
Let me know if you need some big caps - I have a few lying around that you may be able to use. I am not sure of their rating right now, but they are big and I have three. I was going to use them to build a power supply, but I ended up finding drives with a built in supply. Mark |
