Will this system work for what I need it to. I am converting a Sieg X3 and i picked this up really cheap. It is a 4axis controller and driver system. I was going to build my own with gecko's and such but this was much cheaper and it seemed to have everything i needed. I didnt properly research the item enough before I bought it which is my stupidity. Will i be able to use Mach3 or am I stuck with its terminal software. It seems from everything that i've read that the controller and driver are integrated into one part. Please let me know. Thx
Brochure
http://www.neat.com/products/electronics/pdf/300.pdf
Manual
http://www.neat.com/techinfo/pdf%5CNEAT_300.pdf
It looks like you write a and download a program through the serial port for stand alone operation, that would probabally be good if you were doing repetitive production jobs. Although it does hold multiple programs.
It may get a bit restrictive if you want to do one off's etc.
It appears to be programmed in native language only so G code is probabally out.
