| Hi i'm building a very special jet turbine and its bearings are designed for max 120,000rpm. I've looked all over google for homemade tachometer circuits. I could use either 2 magnets for a magnetic rpm circuit or i could use a light probe? Does any1 know of a simple rpm tachometer i could build. Any circuit schematics or info would be great. I'm not the best with electronics but i've built a couple of small little circuit boards from parts from radio shack and simple designs off internet sites so i have some expirence with circuits. It would need atleast 4 digits in its screen and it could be digital, led, i just need anything that will do the job. I can play around with different designs and make them work as long as the electronics are taking care of. Anybody have anything?? Thanks |
| National Semi http://www.national.com/pf/LM/LM2907.html Al.
| The LM2907 doesn't get much easier than that, if you want simple, look at the off-the-shelf items like RedLion products from DigiKey. Al.
| The only thing easier than an LM2907/LM2917 is to BUY something already made..... You might also find the following thread to be QUITE pertinent to this particular inquiry, especially with regard to doing internet research: http://www.cnczone.com/forums/showth...9&page=1&pp=15 specifically post #15 Although the Red Lion stuff is off the shelf, it is not necessarily cheap. The 2907/2917 deal could give you a tach for $10 or less (plus the cost of a VOM) depending on what you already have. |
#11
__________________ Kenneth Lerman 55 Main Street Newtown, CT 06470 |
#12
| An optical solution would be easiest and most probably, more robust. I have to go with NC Cams on this one - the LM2917 is definately a plug and play solution. Buy a cheap multimeter and build a circuit based on the LM2917 to output ~10mV per 1000RPM and you're done. Aaron |
