A simple question would be easier to answer.
Planning on buying or building a power supply?
If buying:
Voltage and current requirements might result in a very, very expensive power supply to power all the servos. Same goes for seperate supplies for each servo. Determining factor is Voltage and KVA rating.
If building:
It might be more economical to build a supply for each servo according to the voltage and current requirements, especially if the voltage is something of a standard value, and the current required is 15 amps or greater per servo.
If the total current required for all servos is 30 Amps or less, this can be accomplished with a single power supply. It normally is not economical to build supplies larger than 30 Amps. If more current is required, the best route is to parallel identical power supplies.
Space available:
Is un-limited space available for this power supply/ or power supplies. Space required will determine whether one or multiple transformers are used. Also, One also must have space for fuses, rectifiers, and filter capacitors.
These are some factors which must be considered. Sorry, I could not fully answer your question.
Hope this helps in your decision.
LinkBack URL
About LinkBacks
