Hi gang! My friend is trying to make an art project in which 2 mylar balloons trigger little audio snips when they hit one another. she has got these little play\record boxes that are triggered with a push switch. I have found that running 9v through the balloons with a multimeter in series set for the sensitive 2v (.000) setting usually responds with from .001 to .050vdc when they hit each other.. i want to take this small input, and trigger a relay..i have a basic stamp available and tons of cmos and ttl logic if that helps.. i can order parts.. i think i need an op amp circuit to trigger a 555 latch of some sort? yeah? Even suggestions of how to search google for this info would help. I tried 'mesuring small voltages' and it is all about differential voltage measurements for current sensing.. ![]() Thanks! |
| Look into the circuitry that involves "touch pads", ala those that sense if you touch a lamp to turn it on and off. As I recall, they use an op amp and the resistance or capacitance change of your finger to turn of/on 120vac circuit. |
| http://www.aaroncake.net/circuits/touch.htm such as this.... i am not sure.. will this circuit trigger off a very small resistance change? the balloons do not seem to effect the resistance measurement... |
| That should be a starting point for you. I"d think that something with a 1 to 50 mv signal should be enough to amplify so as to trip a switch. We were able to get a CA3160 cmos high impedance op amp to trip at a slowly changing "peak sensing" voltage circuit fairly easily and predictably - we were looking for a 10 mv differential. You might want to "debounce" the circuit by feeding the output from the CMOS chip in the link to a 555 based monostable to give you a finite and tuneable output pulse. |
| thank you for your quick reply Yes. Debouncing, but especially the higher driving current and adjustable 'sustain' of a 555 is why I figured 'comparator and 555'. Reliability is a factor as this is supposed to spend a month in a public art gallery.. One thing that is encouraging is the fairly reliable response of the multimeter. The balloons are held apart and we fluttered our hands to simulate human traffic in the space. When the balloons knocked against each other fairly hard, there was a .001 to .005 fluctuation in the otherwise flat .000 readout wired in series with the 9v battery. The first thing I thought of was a really sensitive comparator circuit... But I have only used comparators for IR line tracking sensors.. Nothing this minute... If I understand correctly, I could use a .001 - .025ish reference voltage(somehow) as the comparison voltage, so any time the balloons knock together and transmit more than that, a postive pulse can trigger a monostable circuit of some sort(555?) and in turn trigger a relay or transistor or similar? The response is very appreciated. I would very much like to help my friend. I have got an array of op amps handy, but no dual-voltage power supply.. Do I need the + and - supplies to use these sorts of op amp circuits? Robert |
| Since Mylar is not very conductive you may want to try a circuit like one of theese that use capacitance. Just gound one of the ballons and use the other to sence. http://www.discovercircuits.com/C/capacitance-sw.htm |
| I'm sorry, I'm a confused. DO the baloons touch *each other* or does *she* touch them? Is the surface of each baloon conductive, or is there some sort of film on them that prevents you from using them as a simple contact closure? |
| If you are trying to sense 1 to 10 mv above ground without a bipolare supply, that is going to be tough. You don't need to get fancy to create a +/- power supply - two 9 volt batteries can be configured to do it - if the proper amp is used, they should last for long enough to have the display function for the desired time. The CA3160 was sensing a 10mv DIFFERENTIAL in a sample and hold circuit BUT the voltage differential was way above ground. Linear Technologies has a number of "ground sensing" op amps and comparators that might work for you. I'd still look at crafting up a bipolar supply to simply make life simpler - "finding" that small of a differential is hard enough without having to do it at/near ground without a bipolar supply. |
#10
| Mylar is a good insulator and you're probably seeing a capacitive coupling when they hit. Off the top of my head, my sugestion kind of mirrors NCcams, an op amp in the first stage, LM321 or LM324 something that has extremely low input current requirements. Power it with the same supply as your basic stamp and experiment using a gain of 100 to 1000 and see if it would interrupt your basic stamp. Usually a micro has an edge sensitive interrupt. If you can get it to interrupt it reliably, then make your interrupt routine do what you want. i.e. drive a relay or....
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
#11
| Set the balloons up as a "switch" driven with an oscillator running if the high kilohertz - a few volts should be enough (555 timer). Feed that into an OPAMP (741) biased at about mid supply level. Use the output of the amp to trigger a one shot (555). Aaron |
