Old 01-02-2004, 07:54 PM
capitalv is on a distinguished road
how do i determine what size stepper motors to use?
I just picked up (3) Nema 23 80oz./in. ,6 volt, 5 ohm, 1.2 amp per phase, 1.8 degree, 6 wire, can be wired unipolar or bipolar. what do I look for in a good torque rated stepper motor. I don't have a clue. Thanks.
Old 01-14-2004, 05:47 PM
Jcadwell is on a distinguished road
What do you want to build? Those are low output motors. Perhaps a dremel sized PCB mill/drill could use those. Likely not anything much bigger.
Old 01-15-2004, 09:47 PM
I want to build a small (2' x 2') cnc router. I plan on using these motors with a Xylotec control.
Old 01-20-2004, 02:22 PM
DJ Morrow is on a distinguished road
If you used gears and belts, could he gear it down, to say 2:1 and then go with perhaps a laminate trimmer ? Or would it be too slow to move the router ?
David J. Morrow
Does anyone know of a controller board for synchronized stepper motors Yellowbeard Stepper Motors and Drives 2 04-03-2005 11:06 PM
Looking for controller board for synchronized stepper motors Yellowbeard General Electronics Discussion 0 04-02-2005 08:50 AM
Stepper Motors size? mtsrose DIY-CNC Router Table Machines 7 12-14-2004 10:21 AM
Stepper Motors kellogs72 Stepper Motors and Drives 1 11-29-2004 07:27 PM
disassembly of stepper motors dhprc2 General Electronics Discussion 8 06-25-2003 07:09 PM
