Hi there: I've got my eye on a 1.5KVA transformer at 52Vac and 12Vac. Rectified to DC, I should get 72V @ 20A on one secondary and 17V @ 4A on the other. The larger secondary is getting close the the G320's ratings (given voltage fluctuations, etc) - anyone see a problem here? On the smaller secondary, would this work to power the G100? Am I in danger of tripping my 15A breaker with this power supply? The math says 1500VA/115V = 13A, but I know mains voltage can range quite a bit. Practical experience welcomed! Bonus question: are the popular limit switches happy with 17V? |
| Slow blow fuses and/or small size limit infeed wiring can help tame the inrush current problem. HOWEVER, If you pull the rated 20 amps for the one winding, you'l fry 15 amp fuses regardless of the precautions you take to the contrary. Current draw is a function of load - your high amp transformer will not 'SHOVE' current into motors - they'll draw what the motors or downstram load draws currentwise. Check the sum of locked rotor current ratings and figure accordingly. this might help: CNC Dictionary http://www.cnczone.com/forums/showth...662#post186662 http://www.thewarfields.com/MTCNCDictionary.htm Electronics books http://www.forrestmims.com or http://www.amazon.com/gp/product/pro...lance&n=283155 What gage wire to use: http://www.cnczone.com/forums/showthread.php?t=17350 http://www.cnczone.com/forums/showth...480#post136480 Wiring practices: http://www.a-m-c.com/download/docume...gpractices.pdf There is no "universal limit switch voltage rating". What is/are the voltage rating(s) of the "popular limit" switch(es) that you're using? |
If you intend to power the 5 Volt pin on the G320's or G340's from the 17 Volts DC, it will have to be regulated to 5.0 Volts. The current required by the Gecko is only about 20 milliamp per drive. Also, if you intend to use a parallel port breakout board and run the limit switches via the board, the limits will be switching only 5 VDC logic level signals. Most industrial type limit switches are rated at 115/240 VAC at either 15 or 20 Amps AC, so the 17 volts would not be a problem with this type limit. |
| Cool. This means I might be OK running them off of the G100 @ 12V. |
