Old 09-03-2006, 02:50 PM
interflexo is on a distinguished road
Separate 24V DC supplies
In an industrial quality solution should I have separate 24V DC supplies for solenoid valve or relay actuation and other for inductive proximity switches? I’m posing the question because Bero proximity switches manual regarding cable routing specifies a minimum clearance or shielding to avoid interferences.
Regards
Old 09-03-2006, 03:48 PM
Al_The_Man's Avatar
Although having separate 24vdc supplies for inputs and outputs may be considered ideal, I have never experienced a problem in using a common supply, Either use a common regulated 24vdc supply or if unregulated, make sure there is sufficient capacitance to keep ripple to a minimum.
If you set up a common ground plate and take the power supply common's and all shields to this common point, then this should take care of noise sensitive devices.
