Ok, now that I've been throughly (much by my own doing) drown in imformation. Ok, This is where I'm at right now. (Things are working, or at least moving in a linear fashion). I'm using this controller, http://www.stepper3.com/31.htm I'm using these three motors, http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2582180840 I've hooked into the +lines 1 ohm resistors(no idea what the watts are). PSU, is standard older ATX 300 watt. I'm running KCAM4.0. (Have noted, I should use TurboCNC). on a Win98 system p166 -w- 32 mg ram standard laptop. I was noticing some flatness on circles, say larger than 3" dia. This flatness occurred on the x-axis. (I was told this could be caused from a machine/mechanical problem). Check system, Same type x-axis configuration as y-axis. (would think flatness would occur in both directions if mechanical). Check motors, x-axis motor seemed to be really light in the torgue area. (this was while running KCAM4.0). Tried TurboCNC, the torgue output was there for the x-axis but seemed to stutter somewhat.) ??Idea's?? I downloaded the resistor calculator. If my controller has "FETS" my motors require 5.00 ohm /7.2 watt resistors. If my controller has resistors. my motors require 4.25 ohm/6.12 watt resistors. FETS and RESISTORS are alien to me. as are the watts for the motor power resistors. Can I find the required power riesistors given the info above? And do I have a decent setup for a homebrew system? Thank you much in advance for any input. Merry Christmas. Peace In GOD Neil |
| Homebrew CNC Lathe | Deviant | General Metal Working Machines | 24 | 03-06-2005 09:38 AM |
| Coolant & Swarf problems on Homebrew CNC Systems | UKRobotics | General Metal Working Machines | 1 | 01-17-2005 11:26 PM |
| Screen Door bearings for Homebrew CNC | macmiester | DIY-CNC Router Table Machines | 4 | 01-16-2005 03:53 PM |
| Imformation overload, Homebrew CNC | thuffner3 | Machine Problems, Solutions , Wireless DNC, serial port | 8 | 02-27-2004 11:20 PM |
