Old 12-17-2003, 05:25 AM
alanhunt is on a distinguished road
Stepper motor current
Hi
I am trying to determine the maximum current for my stepper motors. The original controller is no more and I have built a new one (L297/L298) based on my own design. Unfortuanatly I do not know what the vref voltage and hence the current limiter was set to.
The motors are marked Nanotek - Munich and have a resistence of 3.2ohm/phase and are 17 size. I am pushing a peak of 1A through them at the moment but torque seems to be lacking and motors do not get even barely warm.
I have checked the o/p of the sense resistors with a scope, and I'm getting what I think is ok- voltage of 0.5v (0.5ohm resistors) but only on for 5-30% of the time. There are though pos and neg spikes (noise?)
Any advice would be appreciated
alan
Old 12-17-2003, 06:37 AM
limbo is on a distinguished road
I would expect them to be around 1.4A/phase. My astrosyns are 3.4V/1.4A too. Nanotec has several steppers around 3.2Ohm, and they seem to be 1.4A for 17 and 23 size. Check out www.nanotec.de
greetings,
John
Old 12-17-2003, 07:00 AM
Sorry, I made a mistake.
Just looked it up. My astrosyns are 23 size, 3.5V,1.4A, so that makes them 2.5Ohm. Can't compare them to yours.
I looked in the astrosyn datasheets to find a comparable one and found this example:
17 size, 3.1Ohm, 3.7V, 1.2A.
In the nanotec datasheets I can't find your type exactly, but comparable ones are also around 1.2Amps, assuming its a 4lead bipolar type. Sorry for the mixup.
greetings,
John
Old 12-18-2003, 09:58 AM
Hi John
many thanks for your help, did try finding nanotec's web site before but with their name ending as 'tek' nor tec!
I emailed them with the exact number on my motor and just recieved a reply telling me that 1.4A/phase is what I should be using- so far everything is ok again
thanks again
alan
Attaching a Stepper andy_ck87028 DIY-CNC Router Table Machines 4 12-24-2004 11:09 AM
Not good for a stepper motor? FLUTE HEAD Stepper Motors and Drives 4 12-01-2004 11:31 PM
Stepper motor spec' source & question Damachine DIY-CNC Router Table Machines 4 04-06-2004 01:01 PM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 01:18 AM
disassembly of stepper motors dhprc2 General Electronics Discussion 8 06-25-2003 07:09 PM
