Old 08-18-2006, 06:32 PM
cibressus is on a distinguished road
Multiple Signals on a Cable
When putting more then one signal on a cable, like with DSL, how do you prevent the effects additive interference from altering your signal.
Old 08-18-2006, 07:13 PM
fyffe555 is on a distinguished road
Do a search on multiplexed; Multiple signals down one wire. Multiple Analog signals are usually split by frequency, FDM. Digital signals are split by Time slicing TDM. DSL isn't, strictly speaking multiplexed as it's a digital signal at a high frequency, IP over an analog signal - telephone.
Old 08-19-2006, 07:34 AM
there split by frequency, but what about the constructive and destructive interfereance patterns when the two waves meet.
Old 08-19-2006, 08:50 AM
NC Cams is on a distinguished road
A special highly secret, complex method is used to keep the signals discrete : FM
FM=frigging magic
Old 08-19-2006, 09:34 AM
Find a spiritualist and ask Hedy Lamarr.
Old 08-19-2006, 10:28 AM
?? Do you listen to music? can you hear different notes? While the sum of several notes/frequencies is a third wave form with additive and subtractive total the original signals are still there.. Multiplex does the same thing. A filter is used to select one frequency range and interpret the signal in that frequency.
Old 08-19-2006, 10:34 AM
Which is why Hedy Lamarr was able to invent the technique along with her partner a few decades ago.
Old 08-19-2006, 05:59 PM
pastera is on a distinguished road
The different frequencies will only mix (create new components) if they are sent through a non-linear device.
Aaron
