Results 1 to 3 of 3
Thread: Mpg?
    Dec 2003
    UK
    Mpg?
    How does one go about connecting an MPG to a computer ? Am I right in thinking an MPG is just an encoder with a handle on it ?
    How many parrallel port pins would it consume?
    Dom
    http://www.ukrobotics.com/projects
    Apr 2005
    finland
    Quote Originally Posted by UKRobotics
    Yes, an MPG gives out the same kind of A/B quadrature pulses as an encoder normaly does. Most MPGs do not have an index pulse I think.
    Detents might be nice, i.e. the handle stays put in one position if you don't touch it even if you accidentaly push or tilt the MPG.
    Two, encoder output A and B. Depending on how many pulses per rev your encoder is the inputs need to be read fairly fast.
    I've done it with EMC and a 100ppr jogwheel, don't know about other software.
    Registered BobWarfield's Avatar
    May 2005
    There is some useful information on MPG's here:
    http://www.rogersmachine.net/index.html
    Best,
    BW
