Old 12-04-2003, 09:13 AM
CNC Brute is on a distinguished road
amps/phase question
What do they mean by amps per phase?
I'm looking at the xylotex board and it has a limit of 2.5A/phase. The motors I am looking at:
http://www.pontech.com/products/vexta/pk296.htm
These are 2A per phase, does phase refer to each motor? Example, if my X axis is running at the same time the Y is, will I blow my board?
Thanks,
Matt
Old 12-04-2003, 10:00 AM
ger21's Avatar
Most stepper motors have 2 phases, and are rated at amps per phase. The Xylotex can deliver up to 2.5a/phase, per motor, for up to 3 motors on the 3 axis board. So you could use 3 of the motors you're looking at. But, you're torque will probably fall off very rapidly as speed increases, due to the higher voltage rating on those motors.
Extremely basic machining question. touser General Metalwork Discussion 9 06-19-2005 12:51 AM
Question about power supplies dowling177 General Electronics Discussion 1 01-28-2005 07:01 AM
Hobbycnc controler question chas Hobbycnc (Products) 3 09-09-2004 05:00 PM
Just a question about plunge milling. Machine1 Hard and High Speed Machining 4 01-28-2004 08:36 PM
HF lathe question rs1300 General Metal Working Machines 0 01-19-2004 11:22 AM
