Old 07-10-2006, 06:14 AM
najnielkp is on a distinguished road
bridge rectifier output
hi all, i am building my power supply and using 400v 50 amp bridge. i have 112v ac input to it, but only get 100v dc out. do some bridges reduce voltage ? i was expecting 112v x 1.4 = 156v.
Old 07-10-2006, 07:12 AM
gar gar is offline
gar is on a distinguished road
060710-0702 EST USA
najnielkp:
The RMS value of a sine wave is 0.707 of the peak. The average voltage of a full wave rectified sine wave is 0.636 of the peak. 0.636/0.707 = 0.900. 112 x 0.9 = 100.8. Then there is a slight diode drop. So you are getting exactly what is expected.
Put an appropriately large filter capacitor on the bridge output and you will get approximately the peak of the sine wave. 112/0.707 = 158. Note 1.414 is the square root of 2, and .707 is 1/2 the square root of 2. Use calculus to calculate the RMS and average relations to the sine wave peak.
Old 07-10-2006, 08:14 AM
Madclicker is on a distinguished road
Put a filter cap on it and you will probably see the right number. The output of the bridge is still an ac signal until you store it in a cap.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 07-10-2006, 11:05 AM
thanks for all your replies.
