I found this ebay item and i was curious what you guys thought about the specs. It looks nice and its only $50.. http://www.tracopower.com/products/tsl.htm Traco Power TSL480-155PX Industrial Power Supply Input: 93-264VAC Auto-ranging, 50/60Hz Output: 48-55VDC Adjustable, 480 Watts, 10A Screw-Terminal Input and Output Universal Input Voltage Output Voltage Adjustable Short-to-Ground for Negative Voltage! Metal Case (Aluminum), 9x5x5in Easy Snap-On Mounting on DIN-Rails -155 Model Is Custom -148 Model with Wider Operating Temperature Range Low Harmonic Emissions on Input ('P' in the model#) Extremely Low Output Ripple and Noise ('X' in the model#) High Efficiency Overload Protection Parallel Operation Possible CE Compliance to European EMC and Low Voltage Directive Compliance to EN 61000-3-2 (PFC) Conducted Emissions to EN 55011, Class B, and FCC Part 15 Level B Noise Immunity to EN 50082-2 Safety Approvals to IEC 60950, EN 60950 (SELV) UL/cUL 1950, and UL 508 These power supplies are brand new, still in box. They were used both as bench power supplies on our manufacturing/test line, and as in-unit 48v power for a product that we manufactured for the telecom industry. Unfortunately, we are closing the business and are forced to sell our entire inventory of these $300+ units for pennies on the dollar. edit: Added url to manufacturers spec |
| The motors are nema 23 180oz-in, 4 volt, 2 amps. If my calculations are correct im going to need some 22 ohm resistors, 2 per motor. They should be atleast 100W. The resistors come up to something like $137 on mouser.com and the powersupply $50. One bonus with those powersupplies is that you can hook them together in parallel. and at $50 they are not very expensive. Do you have any suggestions where to get heatsinks? mouser doesnt have anything like what i'd want (one big heatsink for all the resistors to attach to) |
| Your calcs are correct for resistors needed. Your powersupply will need to be 12 amps min. for 3 motors. You may be better off to forget the resistors and get a xylotex board which won't need any. You won't be able to run 48 volts on the xylotex tho. Also price the 11 ohm, 50 watt resistors, two in series will make 22 ohms, 100 watts. I am not sure which way is cheaper. If you can find an old stereo amp sometimes you can find heatsink material in them... Eric
__________________ I wish it wouldn't crash. |
| Dale resistors? This HS might work. If thats too small, one big HS is usually hard to find and expensive when you do. All Electronics has some individual HS's you could use, CAT# HS-78, for $2.50 ea. Are you going to fan force cool the HS? Thats a lot of watts to burn up. mike |
I believe the resistors need to be 88 watt, would you think 100w is enough with some good cooling? or do i need to go with 2 11 ohm 100w resistors to increase the rating? |
| 100 watt 22 ohms will be fine. Put a fan on there. They will be HOT. This is normal. I agree that 48 volts will give you better top end speed. Speed always costs money... ![]() Eric
#10
http://www.mouser.com/catalog/616/394.pdf
#11
yep, looking at a 48V 12A PS on mouser will run you over $500.. i had pretty much given up on that until i found the ebay one for $50. Would you suggest mounting 2 of them in parallel so that it'd be 20A? you said it would need 12, will 10 be ok? i guess for $50 it'd be safer to just put in 2.. |
#12
| One would be pushing things..... If you do go with 2, put one on the z axis and the other on the x and y. You could also go 24 volts on z and 48 volts on x and y....assuming you already have a 24 volt supply kicking around. Eric
| How does a power supply work. | ynneb | DIY-CNC Router Table Machines | 1 | 07-27-2011 09:40 AM |
| Need more power | mvaughn | General Electronics Discussion | 49 | 06-15-2005 06:11 AM |
| 5 Volt Power Supply Tripping | murphy625 | General Electronics Discussion | 13 | 02-27-2005 09:05 PM |
| Choosing a Power Supply for Retrofit? | pfeist | General Metal Working Machines | 4 | 05-23-2004 10:36 PM |
| 48V Power Supply Source ?? | ninewgt | General Electronics Discussion | 7 | 06-25-2003 10:10 PM |
