Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Need help locating a connector
    Registered DennisCNC's Avatar
    Aug 2005
    Clearwater, FL US
    Cool Need help locating a connector
    I have been looking and looking and can't find anyone that sells a mating connector like this. It is ~1.8mm pitch double row. I'm about to solder some wires to this thing and put D-sub parallel port and 15pin VGA connector on to it.
    Any help appreciated!
    Attached Thumbnails Attached Thumbnails Need help locating a connector-connector12.jpg
    Dennis
    Gold Member widgitmaster's Avatar
    Jun 2005
    Cool
    http://www.action-electronics.com/conidx.htm
    Also Try calling MOUSER Electronics 800-346-6873
    http://www.mouser.com/
    Talk to one of their EE's, they are very helpfull and will find exactly what you need!
    They have NO minimum orders, so you can order just one little connector!
    I have done business with them, they are pro's in ever respect!
    Eric
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Aug 2005
    Clearwater, FL US
    I looked through Mouser's site but didn't think about calling.
    Thanks!!!
    Dennis
    Aug 2004
    Find AMP....they make metric connectors.
    Aug 2005
    Clearwater, FL US
    ^^ Emailed AMP and they said they don't have anything like that.
    Dennis
    Jun 2005
    I think the connectors you need are called IDC, not sure what it stands for tho!
    They usually connect to flat ribbon cables!
    Jun 2005
    Dec 2003
    Quote Originally Posted by widgitmaster
    'Insulation Displacement Connector'
    I think the pitch is off IDC are .1
    Registered leberen's Avatar
    May 2006
    If you have had no luck so far, try www.digi-key.com, they like mouser have a book they can send you as well, its handy to have layin around
    Jun 2003
    Boalsburg PA
    Those connectors are 2mm. It's very common nowadays. Digikey sells 2mm idc headers. I actually have a set of connectors (made by hirose) for that amp in my hand as I type this. Sorry, no part number. I'm a little annoyed at API, the connector part number is not in the manual as far as a 5 minute scan will reveal.
    I have bought individual pin 2mm idc headers. If digikey has a built up cable, I suggest you go with that unless you have incredible dexterity. I've always just searched for 2mm
    My thought is you measured the distance between the two ends of the 24 pin connector and divided by 12, mostly because I make that mistake all the time. This give you a pin spacing of 1.8 mm. You should divide by 11, giving the correct 2mm.
    Aug 2005
    Clearwater, FL US
    ^^Why can't it be simple!! Thanks a lot for the info!! Finaly light at the end.
    Looks like it is the DF11 Series Hirose.
    Dennis
    Jun 2003
    Boalsburg PA
    I think you meant DF11, which looks correct
    Have you ever figured out anything about the software for these drives?
  • Page 1 of 2 12 LastLast
