I've searched but have not seen a comprehensive side-by-side comparison of controller hardware for driving Stepper motors. I'm still somewhat of a newbie so I may need more columns to get a useful comparison. Any info. or suggestions you could provide would be helpful. I'll update the table in this first post as new posts, suggestions, and input is added. Code: |Kit|U/B|Axis|Opto.|Type|_Steps|MBRD|$/Ch|Amps|Volts|_Tech_|_Controller_____| |###|###|####|#####|####|######|####|####|####|#####|######|################| |PCB|_U_|__1_|__.__|__._|___Y__|__._|$_22|__3_|_55__|18245T|_PicStep________| |PCB|_U_|__1_|__.__|__._|___.__|__._|____|__5_|_30__|IRLZ44|_PMinMO_________| |PCB|_B_|__1_|__.__|Chop|__400_|__._|__._|_2.5|_46__|L297/8|_PMinMO_________| |PCB|_U_|__3_|__.__|__._|___.__|__._|__._|__5_|_30__|_3977_|_PMinMO_________| |Kit|_U_|__4_|__N__|Chop|_3200_|__._|$_25|__3_|_42__|_7062_|_HobbyCNC_4AUPC_| |Kit|_U_|__1_|__N__|Lin.|_3600_|__N_|$_30|1.5_|_35__|TIP122|_Linistepper____| |Kit|_U_|_>3_|__N__|Lin.|_3600_|__N_|$_25|1.5_|_35__|TIP122|_Lini-InQty.____| |Kit|_U_|____|__N__|____|__200_|__N_|$___|3.0_|_35__|TIP122|_Lini-NoMicro___| |_N_|_U_|__1_|__N__|__._|__400_|__._|$__4|1.25|_35__|_5804_|_UCN5804________| |_._|_._|__._|__.__|__._|___.__|__._|$___|__._|__.__|_3977_|_3977/a3977_bd._| |_._|_B_|__3_|__.__|__._|_1600_|__._|$_52|_2.5|_35__|______|_Xylotex 3-Axis_| |_._|_B_|__4_|__.__|__._|_1600_|__._|$_46|_2.5|_35__|______|_Xylotex 4-Axis_| |_N_|_B_|__1_|__Y__|__._|_2000_|__Y_|$114|_7.0|_80__|Propri|_Gecko G201_____| |###|###|####|#####|####|######|####|####|####|#####|######|################| |Kit|U/B|Axis|Opto.|Type|_Steps|MBRD|$/Ch|Amps|Volts|_Tech_|_Controller_____| Kit - KIT-Comes in a kit; PCB-PC boards available only. U/B - Unipolar or Bipolar? (U/B) Axis - # of Axis (or Channels) Opto. - Does it have Opto-Isolation? (Y/N) Type - Chp-Chopper, Lin=Linear Steps - Steps per revolution, assuming a 1.8deg. motor. $/Ch - Cost per Channel or Axis MBRD - Mid-band resonance damping? (Y/N) Amps - How many Amps will it support in the given mode? (Per Phase) Volts - Max. volts supported. Tech - The technology this driver is based on. (3977, TIP122, etc.) - - PROS - - PicStep - OPEN SOURCE PMinMO - OPEN SOURCE Gecko - Powerful? HobbyCNC - Xylotex - UCN5804 - Really Cheap, easy to build Linistepper - Less Expensive, versatile, OPEN SOURCE. 3977 - - - CONS - - PicStep - Soldering Required, No Kits available PMinMO - Soldering Required Gecko - Expensive HobbyCNC - Soldering Required Xylotex - UCN5804 - Soldering Required, Really low power Linistepper - Soldering Required 3977 - Other related questions: If a controller is NOT a Chopper or a Linear, then what is it? [Edit: Added MBRD, Volts, Reformatted, Updated] Last edited by Rance; 06-05-2006 at 03:02 PM. |
| Well for the PICstep and the PMinMO 3977 you have the choice of 3 axis opto isolated or 4 axis without. Both can use the same breakout borards I believe. There is a spreadsheet for the 3977 on PMinMO's site that includes the component costs. Total cost depends on if you buy boards or make them... but it lets you figure it out. Roughly $120 for a 4 axis setup. |
| I hope this will be more readable. The trick is to select the table and click the "#" tool or just put "|CODE]" at the start of the table and "|/CODE]" at the end but replace the "|" with the open square bracket. The thing won't let me show you an open square bracket 'cause it thinks its an actual code command then. Code: |Kit|U/B|Axis|Opto.|Chop|M.Step|MBRD|Cost|Amps|Volts|_Tech_|_Controller_____| |###|###|####|#####|####|######|####|####|####|#####|######|################| |_._|_._|__._|__.__|__._|___.__|__._|$___|__._|__.__|18245T|_PicStep________| |PCB|_U_|__3_|__.__|__._|___.__|__._|Clik|_5._|__.__|_3977_|_PMinMO_________| |_._|_._|__._|__.__|__._|___.__|__._|$___|__._|__.__|______|_Gecko__________| |_Y_|_U_|__4_|__N__|__Y_|___Y__|__._|$25_|_3._|_42__|_7062_|_HobbyCNC_4AUPC_| |_._|_B_|__3_|__.__|__._|___.__|__._|$___|__._|__.__|______|_Xylotex________| |_._|_B_|__4_|__.__|__._|___.__|__._|$___|__._|__.__|______|_Xylotex________| |_._|_._|__._|__.__|__._|___.__|__._|$___|__._|__.__|_5804_|_UCN5804________| |_Y_|_U_|__1_|__N__|__L_|___Y__|__N_|$30_|_1.5|_35__|TIP122|_Linistepper____| |_"_|_"_|_>3_|__"__|__"_|___"__|__"_|$25_|__"_|__"__|__"___|_"_Qty_Discount_| |_"_|_"_|____|__"__|__X_|___N__|__"_|____|_3._|__"__|__"___|_"_w/o_Microstep| |_._|_._|__4_|__.__|__._|___.__|__._|$40_|__._|__.__|_3977_|_3977/a3977_bd._| Kit - KIT-Comes in a kit; PCB-PC boards available only. U/B - Unipolar or Bipolar? (U/B) Axis - # of Axis (or Channels) Opto. - Does it have Opto-Isolation? (Y/N) Chop - Is this a Chopper? (Y/N/L) L=Linear M.Step - Does this suport Micro Stepping? (Y/N) Cost - Cost per axis MBRD - Mid-band resonance damping? (Y/N) Amps - How many Amps will it support in the given mode? (Per Phase) Volts - Max. volts supported. Tech - The technology this driver is based on. (3977, TIP122, etc.) - - PROS - - PicStep - Gecko - Powerful? HobbyCNC - Xylotex - UCN5804 - Really Cheap, easy to build Linistepper - Less Expensive, versatile, OPEN SOURCE. - - CONS - - PicStep - Gecko - Expensive HobbyCNC - Soldering Required Xylotex - UCN5804 - Soldering Required, Really low power Linistepper - Soldering Required I've updated the cost column to be per axis and included the estimate provided for the 3977. I split the Linistepper into three lines to show the different options including quantity price and higher amp rating in non-microstepping modes. I sell the Linistepper kit, in case you didn't know. Anyone else that can fill in some of the missing data for the other units? Perhaps the 3977 should be split into a few lines to show different options? Pricing for the others? |
| James, Thanks for the tip on using CODE. [I split the Linistepper into three lines to show the different options including quantity price and higher amp rating in non-microstepping modes. ] Hey, I don't see where you split this out. I'd be glad to do this if you want to email it to me. Each time I find out more info, I update Post #1 to reflect the changes. Thanks everyone for their input, both past & future. [Edit: Doooooooh, I'm blind as a bat. Thanks James.] Last edited by Rance; 06-05-2006 at 12:07 PM. |
| In my copy of the table (post #5 above) there are two new lines under the Linistepper line. The first one reflects the quantity discount and allows the "($75 for 3)" text to be removed from the prior line which gets rid of the horizontal scroll bar in the CODE area. The second new line is just under that and reflects the higher power available if you don't use the microstepping modes. I also updated the Ledgend to indicate Linear vs Chopper: "Chop - Is this a Chopper? (Y/N/L) L=Linear" |
#11
| Errr... yeah, I guess so. Good point, .CSV would be just fine, assuming people would stick to that and not post back .XLS or whatever... And assuming people could load that... Code: Kit,U/B,Axis,Opto.,Type, Steps,MBRD,$/Ch,Amps,Volts, Tech , Controller PCB, U ,1, . , . , Y , . ,$22 ,3,55,18245T, PicStep PCB, U ,1, . , . , . , . , ,5,30,IRLZ44, PMinMO PCB, B ,1, . ,Chop,400, . , . ,2.5,46,L297/8, PMinMO PCB, U ,3, . , . , . , . , . ,5,30,3977, PMinMO Kit, U ,4, N ,Chop,3200, . ,$25 ,3,42,7062, HobbyCNC 4AUPC Kit, U ,1, N ,Lin.,3600, N ,$30 ,1.5,35,TIP122, Linistepper Kit, U , >3 , N ,Lin.,3600, N ,$25 ,1.5,35,TIP122, Lini-InQty. Kit, U , , N , ,200, N ,$ ,3,35,TIP122, Lini-NoMicro N , U ,1, N , . ,400, . ,$4 ,1.25,35,5804, UCN5804 . , . , . , . , . , . , . ,$ , . , . ,3977, 3977/a3977 bd. . , B ,3, . , . ,1600, . ,$52 ,2.5,35, , Xylotex 3-Axis . , B ,4, . , . ,1600, . ,$46 ,2.5,35, , Xylotex 4-Axis N , B ,1, Y , . ,2000, Y ,$114 ,7,80,Propri, Gecko G201 |
#12
| None of these are CNC controllers. They are all simple, low end, stepper Drivers. Fred Smith - IMService http://www.cadcamcadcam.com;hobby |
