Hi, I'm a novice at building CNC machines and I'm in the process of researching/designing a CNC router. After a week of research, I came up with the following design and would be thankful if anyone with expertise would answer my questions. CAD/CAM (BobCAD) ---> TurboCNC ---> Printer Port ---> C1 Isolation Board ---> 3-Axis Motor Driver ---> Motors ---> Router My questions are as follows: a) Is the "3 Axis System Kit" offered by Xylotex (http://www.xylotex.com/3AxSysKit.htm) the best system I could use as a beginner? b) Is my design workable as it is? or are there missing blocks that I'm forgetting about... c) I bought the plans for a router that claims to be both cheap and simple at the following site: http://crankorgan.com/morph.htm is anyone familiar with it? Would you know the source of a simple/cheap router to build? d) What do you suggest I should build the router from? I want it to cut through aluminum. e) Why is the router Z-axis unable to move more than a few inches? is there any way to change the design to fix that issue? Thanks in advance, Hani A. |
| Quick question. What are your intended uses for it? You should be "good to go" for cutting wood, plastic and other relatively soft materials. You might want to go smaller/more precise if you're planning on milling circuit boards. That 3axis kit looks like a good deal. Cheaper than what I built mine from scratch for, and those motors will be more than powerful enough if your friction isn't too bad. |
