| Personally I would not use Cat5 cable for anything but what it was intended for, Ethernet etc. I would think you could go down to 18g but no lower, use separate cables for the encoder. Alpha Cable or Belden are good sources of shielded cables. Al.
| Cat5 cable is a solid conductor wire and will break if flexed enough times. Use a stranded wire for your motors and encoders.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
The encoder shield should in most cases be attached only on one end, and that connection is to the equipment or chassis ground. The servo shield should be attached at one end to the equipment or chassis ground, and the other end of the shield attached to the servo motor housing. Jerry |
| If you have shielded pair cable, that would be the way to go. Al.
