According to the sheet I have the 4 term is - and the 3 term is + input voltage, but regardless the output should be open, are you using a high enough load as if it under the leakage current rate then it will show some conduction.
What kind of load do you have on it, what are you actually switching?.
LinkBack URL
About LinkBacks
