Tell us something more about these power supples,
they sound like AT units (200-250w?) from 286-386 units not ATX?
I don't remember any ATX units with hardwired AC side switches but I could be wrong.
If they are are AT then you only need the minimum resistor load on 5V.
You can cut those wires short and connect them inside if you don't want to control them from the existing switches. Usually a double pole-double throw-switch, wires are brown blue black white? IIRC.
LinkBack URL
About LinkBacks
(it's that cord on the right of the bunddled wires) do you just leave it or do you cut it off? There was a mention to wire the PS up together for power, I guess I can use this cable to do that. I would assume that I just keep the connections the same.
