Old 10-26-2003, 11:17 PM
CNC Pro is on a distinguished road
What to look for in a phase convertor?
What to look for in a phase convertor? I just acquired a machine, and I need to convert single phase to three for my VMC with 15 h.p. spindle. Any suggestions or recommendations?
Old 10-27-2003, 10:40 AM
HuFlungDung's Avatar
Moderator
Hi CNCPro,
It is going to cost you a bit for a convertor, and convertors are "dumb".
Consider an AC variable frequency drive. In smaller motor sizes, they do allow the frequency drive to generate the 3 phase from a single phase input. However, you need to purchase a much larger drive than 15 hp to run a 15 hp motor. This could be as much as a 30 hp drive required. Check with the manufacturers on whether this can even be done with this size of a motor. Baldor is a popular manufacturer of this type of device. A Vector drive (with encoder feedback off the motor) is the absolute best system, because the motor will always run at commanded speed. The cheaper "vectorless drives" will not be as accurate, and also are gutless at speeds less than 10% of rated rpm.
But at least, you will have the option for a variable speed on your spindle motor then, and much nicer to interface with a cnc controller.
A 15 hp load running off of a single phase electrical panel is a significant load. You should talk to an electrician about it.
VFD for a single Phase motor!! Yepez Servo Motors and Drives 4 08-10-2009 07:53 PM
Staggering motors viktorcnc Stepper Motors and Drives 12 10-12-2005 05:56 AM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 12:25 PM
3 phase with idler and draw string only gtslabs General Electronics Discussion 2 06-19-2004 05:11 PM
Rotary 3 Phase Convertors SRT Machine Problems, Solutions , Wireless DNC, serial port 9 06-11-2003 11:34 AM
