Old 10-22-2003, 03:57 PM
thielert is on a distinguished road
transformer sources
I would like to build myself an unregulated DC supply. I see several of you veteran CNCers are using large toroidal transformers in your supplies. I wish to make a 32V ~35A DC supply. I have looked at several transformer manufacturers and can’t find one that suits me. Can anyone point me in the right direction?
Thanks,
Tim T
TT
Old 10-22-2003, 04:29 PM
NeoMoses's Avatar
NeoMoses is on a distinguished road
I seem to remember seeing some at www.digikey.com. Watch out, they're pricey!
Also, www.mpja.com has some inexpensive rectangular transformers that might work for you.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
Old 11-02-2003, 02:12 PM
rdudley is on a distinguished road
xmfr
Just one place, www.plitron.com I've used several of them. Pick you size from their chart and call an order in!!!
Reg Dudley
Old 11-03-2003, 12:42 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
I must agree with rdudley. I have ordered many from them. I really like them.
It may take a little more time to get them because they make them as they are ordered. Also keep in mind that you get two transformers in one. Just connect the output in series to double the amps. You may need to order the 20 AMP toroid and double the output to get 40 Amps!
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 11-03-2003, 01:03 PM
turmite is on a distinguished road
I can't get the link to work! "this page not available"
No greater love can a man have than this, that he give his life for a friend.
Old 11-03-2003, 01:14 PM
plitron xmfr and power supply
If you could tell me what voltage you need and what amperage is required, I'll look up the number of the transformer you should use and post it with a diagram of the power supply circuit with sizes of the filter caps and bleeder resistor along with the rectifier bridge parameters.
Best to get it right the first time!!!
Reg Dudley
Old 11-03-2003, 02:54 PM
Sorry, link is http//www.plitron.com .................
Reg Dudley
Old 04-01-2004, 08:59 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Which one are you using?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 04-01-2004, 09:07 PM
starCNC is on a distinguished road
List some information about your power supply and some pictures please
thank you
StarCNC
Old 04-01-2004, 10:01 PM
CNCadmin's Avatar
Site Owner
Here is good one- http://www.mpja.com/directview.asp?product=6645+PS
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
  #11   Ban this user!
Old 04-01-2004, 10:27 PM
ToyMaker's Avatar
ToyMaker is on a distinguished road
Jeff wrote:
>Just connect the output in series to double the amps.<
Isn't that the other way round, windings in series add voltage and in parallel add current? Or am I confused (again )?
robotic regards,
Tom
"I guess you could say this treatment really whacks a polyp."
- - a doctor reporting on the effectiveness of a procedure
Old 04-01-2004, 11:37 PM
Al_The_Man's Avatar
Tom, your right, windings connected in parallel to double the current. Probabally a slip of the keypad by jeff.
Another thing to keep in mind with Toroidal transformers was illustrated by a call I had from a friend of mine who I had designed a supply for, he picked up a used Toroid txr from ebay and after he hooked everything up and powered up, he blew fuses and the transformer got hot, thinking he had a dud transformer, he called me to take a look.
I noticed right away he had made a mounting bracket for the transformer, because it did not come with one.
He had made a horseshoe bracket over the whole txr and secured it with a long screw through the centre.
What this effectively did was to provide two shorted turns around the toroid causing the over-current.
luckily no permanant damage was done.
Al
How to wire a toroidal transformer..need advice bgolash General Electronics Discussion 15 11-12-2007 09:22 PM
Canadian sources for transformers? The Wizard General Electronics Discussion 4 04-30-2005 11:59 PM
3 phase transformer on single phase? jevs General Electronics Discussion 4 03-19-2005 12:25 PM
Sources for ingots ChrisJ Casting Metals 5 01-24-2005 07:18 AM
Connecting power transformer to 3 phase keithorr General Electronics Discussion 3 12-17-2004 02:52 AM
