Old 04-01-2006, 11:01 AM
aggie_67 is on a distinguished road
PCB Drills
Just getting ready to drill my pcb boards but need to order drills. Problem is I can't find any reference as to what size drills to use. Know it probably depends on components being used but is there one basic size that is acceptable?
Old 04-01-2006, 11:28 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
I think people use 0.6mm or a 1/32" bit, but don't quote me as i have never made one.
Joe
Old 04-01-2006, 11:55 AM
*Registered User*
Carel is on a distinguished road
Hole through chip, resistors and capacitors normally are drilled 0.7-0.8mm, TO220 housings like 5 volt regulators are 1.0mm. You can buy them in HSS or Carbide. HSS lasts approx. 600 holes. Make life easy and use a (mini) drill-press.
Old 04-01-2006, 12:13 PM
joecnc2006's Avatar
www.joescnc.com
oops meant to say 0.8mm 1/32"= 0.766mm
Old 03-05-2007, 11:20 PM
roughrider is on a distinguished road
drills
goto welding suppler get torch tip cleaning drill bit .
littledrikk bitsto clean actaline torch or gas welders
Old 03-06-2007, 07:03 PM
pminmo's Avatar
pminmo is on a distinguished road
.032 #67, is a common usage size for resistors and capacitors, DIP packages,
larger resistors will take a .042 #58 same for TO-220. Diodes many take an .046 #56. Components are different, I start out with .032 because only a few components need drills smaller, and then usually the .032 isn't a problem for those. I'm really getting to like surface mount and saying the heck with drills!
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 03-06-2007, 07:56 PM
martinw is on a distinguished road
Dear Carel,
Excellent advice. Could I add a little?
0.8 and 1.0 mm holes cover most through hole components. If you have discrete wire screw-down PCB connectors, you may need 1.3mm as well.
0.6mm holes may work for most DIL chips, but I tend to avoid them. Too easy to break. Go for 0.8mm instead.
If you are mounting the board on pillars, 3mm holes might also be useful.
Those four bit sizes may not be all that you need, but they are a good start IMHO.
It really helps if you have put a small "hole" say 0.3mm diameter at the centre of the pad on the PCB artwork. This helps you centre the drill bit if you drill by hand, either "freehand" or in a small drill press. I've never had much luck "freehand", but plenty of people have.
If you have to increase the diameter of a hole that you have already drilled, be extra careful. That is when I always break small dia. bits.
One more thing.. it is vital that the size of the pad is large enough to leave a reasonable area of copper after the hole has been drilled. If you do not, when you try to solder the component lead, the copper pad may lift off as it gets too hot.
Best wishes
Martin
Old 03-07-2007, 09:47 AM
fyffe555 is on a distinguished road
Harborfreight has recycled carbide bits from the pcb industry. Work great;
http://www.harborfreight.com/cpi/cta...emnumber=44924
recommend using a drill press or cnc machine, freehand will break them..
