| servo help I just looked again at one of my new servo motors and noticed something I had not noticed before. On part of the label it reads: 1/3 hp PWM It is a brushed dc Reliance motor that will make 980 oz/in at 10 amps. Terminal voltage is 120v with the motor turning 15 rpm for every 10 volts applied. My question is based on an assumption I have had for some time. I though PWM meant pulse width modulation? Does this have any bearing on the step/dir system I had planned to use? turmite
__________________ No greater love can a man have than this, that he give his life for a friend. |
| Leaving the PWM thing aside for the moment, there is something wrong with your numbers. These numbers should mesh and yours don't. Heres why: 1) Kt = 1.351 Kv 2) Watts = RPM * in-oz / 1351 3) There are 746 Watts per Horsepower A Kv of 15 RPM / 10V would mean the motor would have a no-load RPM of 180 at 120VDC. From (1) it would make its Kt = 20.2 in-oz / Amp. At 10A its torque would be 202 in-oz. From (2), its power would be 202 * 180 /1351 Watts or 27W From (3), 1/3 HP = 249 Watts. 27W is not even close. Please check your numbers. One of them is very badly off; the above is a reality check. Mariss Mariss |
| Mariss thank you for your response. I am including here the total info that I have from the seller. These are new motors but were made in 95. Back emf constant, ke=68V/kRPM Torque Constant, kt=5.75 lb-in/amp Rated Peak Torque: 1080 oz/in The 1/3hp PWM is all that is on the motor. The 15 rpm I got from the seller in an email and the 980 oz/in should have been 920. With the numbers above can you help, and at the same time explain the PWM thing for me. turmite
| Small servo systems and power supply | imserv | Product Announcements & Manufacturer News | 4 | 04-03-2008 12:11 PM |
| Using surplus servo motors as spindle drive | Swede | Servo Motors and Drives | 11 | 03-16-2008 09:05 AM |
| Servo Motor Running away. | murphy625 | CamSoft Products | 38 | 02-27-2005 02:08 PM |
| Mixing servo and stepper | ty1295 | Servo Motors and Drives | 0 | 01-19-2005 10:26 AM |
| steppers or servo drives | mmjpotter | Gecko Drives | 14 | 03-30-2004 03:56 PM |
