You've probably already spotted this but the pcb-gcode ulp produces gcode path following the edge of the trace in eagle. Theres no tool offset. That is, the centre of the cutter follows the track edge. If you're isolation milling and your cutter is removing 6mils total width of cut then that will reduce the width of your trace set in eagle by 3mils each side.... So , if you want to leave 10 mils and your cutter is removing 6mils then your trace needs to be set to 16mils in eagle.... The problem then becomes routing and pad spacings...
LinkBack URL
About LinkBacks
