Hi I have this transformer working. It is providing 54 VDC. How do you determine its maxium current rating. Thanks You are bidding on a new 600VA toroidal transformer. It is precisely made for high-end power amp or equipment. It has very low power loss and magnetic leak. Labeled input 115 / 230 VAC 50/60 Hz (single coil with center tap) and outputs 35VAC x 2 (dual coils). Mounting hardware is included. The test results are excellent. Voltage Test Result: TEST CONDITION: Apply variable voltage to primary coil (115V terminals) from 100-180VAC. No load on secondary coils. 1. Primary V = 100VAC, Primary I = .03A 2. Primary V = 110VAC, Primary I = .03A 3. Primary V = 120VAC, Primary I = .04A 4. Primary V = 130VAC, Primary I = .05A 5. Primary V = 140VAC, Primary I = .11A 6. Primary V = 150VAC, Primary I = .15A 7. Primary V = 160VAC, Primary I = .63A Load Test Result: TEST CONDITION: Input 120VAC 60Hz to the primary coil; parallel 2 secondary coils, 10 ohm 250W resistors as dummy load and room temperature at 25 degree C. Temperature rises 6 degree C after an hour test at load #5. 1. Primary I = 0.03A, Secondary V = 40.5VAC at 0.0A 2. Primary I = 1.36A, Secondary V = 39.6VAC at 3.96A 3. Primary I = 2.66A, Secondary V = 38.6VAC at 7.72A 4. Primary I = 3.92A, Secondary V = 37.9VAC at 11.37A 5. Primary I = 5.10A, Secondary V = 37.1VAC at 14.85A Dimension – 5.0" Diameter x 2.7" High |
