Old 02-27-2006, 01:33 PM
Stuff-Builder is on a distinguished road
cnc4pc relay board question
I just set up a CNC4PC solid state relay board. Basically I wired the board into two duplex receptacles, added the 5v power supply, blah blah blah. So the board seems to work fine - turns the appropriate receptacle on and off when the keys are pressed in Mach.
My question/issue is this: the input signal to the board is an active low. The problem is that when you disconnect the board from the parallel port - or turn the computer off - the relays then all close. I found this out this morning when I shut the CNC computer down and the spindle on my mill promptly jumped to speed. Not exactly the most soothing occurance.
Did I do something wrong in my wiring? Is this normal for an active-low output? Anyone used this board and faced this problem?
Thanks,
Scott
Old 02-27-2006, 02:08 PM
mgamber is on a distinguished road
Thanks,
Scott
That's not good. Do you have it wired to NC or NO?
Old 02-27-2006, 02:26 PM
Well there wasn't really any option for normally open or normally closed. Just two terminals for each switch.
The manual is at http://www.cnc4pc.com/Solid_State_Relay_Board.htm, then pick the pdf manual. No mention is made of this in the manual. According to the manual
It seems to have to do with the inputs being active-low, but it does essentially make the board normally-closed.
Ideas?
Scott
Old 02-27-2006, 02:28 PM
Ideas?
Scott
Without product bashing and based on only the information you have given, I'd have to say get a new board. That is totally unsafe.
Old 02-27-2006, 02:36 PM
bcromwell is on a distinguished road
I have the same board, and I am 99.99% sure mine does not work this way. Make sure you have the ground going to both the enclosure and the rs232 gnd pins, if you don't the gound might float after removing the cable turning off the pc. I will test mine tonight but I have rebooted and turned of my computer a lot and never had the spindle or vacume come on.
Old 02-27-2006, 02:38 PM
Just found in the Product manual,
Wiring:
This card works as a set of 4 normally open switches that enables the connection if the power is supplied to the card, and a signal is provided to the appropriate input pin. Please make a note that this card works only for AC devices.
You might have miswired something...
Old 02-27-2006, 03:14 PM
I got some info from Arturo - the guy who built the card. He recommended using a safety charge pump to switch the 5v off when Mach is not running.
He says the parallel port can do wacky things when Mach isn't running.
I might just go ahead and ge the charge pump card. Alternatively I already have a switch wired to turn my stepper drivers off (I get tired of the high-feq. whine). Maybe I'll just wire the 5v relay supply to this switch as well. I never leave the stepper drivers running when I'm not using Mach - too noisy. That's probably the 5 cent solution.
Scott
Old 02-27-2006, 06:59 PM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
I have this card as well, mine doesn't do that. It may indeed be your wiring. You can also do a "Cheap" enable circuit, just have a TTL relay switch your power supply to keep your relays Charged when the enable signal is not present. Mouser makes some solid state relays DC/DC that will work with a 5v signal and then has the power side upto 5-30Amps.
Scott
Old 02-27-2006, 07:18 PM
Something is very wrong with it right now. I just did some testing and I was getting power out of a relay that isn't even hooked up.
I think I may have done something wrong with grounds (???), I don't know. Arturo has been good about getting back to me and asking more questions. He says he hasn't seen this problem before and that the board shouldn't behave like this (a good thing!).
Scott
Old 03-01-2006, 02:15 PM
I've been discussing the problem more with Arturo Duncan at cnc4pc, and he (and I) decided the board must have been damaged in shipping. It's just not behaving the way it should at all.
I give a big thumbs up to Arturo for replacing the board with a new one and picking up the shipping to boot. I appreciate the good customer service!
I did go ahead and buy a safety charge pump board from Arturo as well.
So, hopefully that will take care of everything.
Scott
Old 03-01-2006, 02:35 PM
Al_The_Man's Avatar
Keep in mind that a solid state relay will measure a voltage out with no load connected to it when using a high impedance meter like a modern digital voltmeter, this is due to the inherent leakage of the SSR and the high impedance of the meter. It's is just that this leakage will not support any kind of normal load so you do not see it normally.
  #12   Ban this user!
Old 03-16-2006, 08:40 AM
Al,
Can you explain better? Use small words for a spark-clueless mechanical engineer! Talk to me like I'm four.
BTW, my multi-meter is an old Radio Shack analog unit bought by my dad sometime in the 70's.
With the solid state relays, if I plug just a simple test light into the outlet wired to the relay would it come on from this leakage? Is that a small enough load?
Mass confusion...
Thanks, Scott
