I am building a 2-d pattern cutter and need to control a relay to fire the blade. How do I output from the parallel port to the relay and what g-code software will generate coding for this? Please help. Last edited by amccoy; 02-21-2006 at 09:29 AM. Reason: Typo |
The best thing would be to use a solid state relay to connect the parallel port to control the relay. There are many sources for them. I just happen to know of this source. http://www.cadcamcadcam.com/index.as...PROD&ProdID=56 http://www.cadcamcadcam.com/index.as...ROD&ProdID=125 What control software are you using? Or are you still researching this? Most all control softwares are able to do this. Mach, TurboCNC, DeskCNC, KCam, CNCPro Etc... The software settings use two M codes to generate a signal on and off to the solid-state relay. Example : M55 = Turn on M56 = Turn Off Wayne |
| YOU CAN"T DRIVE THE RELAY DIRECT FROM PARALLEL PORT - YOU NEED A BUFFER!!! Check out "Real World Interfacing of Parallel Port" book from Sams. Do a "parallel port interfacing" search on this site and it will show up. I"m not where I can put my hands on the ISBN right this instant. |
Nikolas |
| Im also searching for the same answer. How to do an ON/OFF control (cut or no cut) I know its possible to do it using the auxiliary code M, but that should be donde manually. Ive been searchong how to do it with visual mill but no answer yet. Well ill keep searching. |
| For the hardware side, Do a search here for 2n7000 very cheap and versatile little component, when you just want one or two buffers. http://cnczone.com/forums/showthread...ghlight=2n7000
