Old 02-20-2006, 05:15 AM
Gads is on a distinguished road
do you need to use both seconderies on toroidal
help
need to purchase transformer, can i buy one rated higher and just use one
secondary output if the volt and amps of one output meets my needs?
I posted earlier but no real answer, this is basicly my main question.
thanks
Old 02-20-2006, 05:56 AM
bill south's Avatar
bill south is on a distinguished road
Hey Gads;
Yes, only use the output you need whcih supplies the correct voltage to drive your motors. Just blank (cut and heatshrink or tape or cap) the unused secondary. Don't short them together!!!!
However, as an option, you can use both secondaries, if they are the same voltage, and up your maximum current! If you attempt this, however, make sure that the secondaries are phased appropriately. There is a thread somewhere that covers this procedure. It's pretty simple but BE CAREFUL . This stuff will turn you into a french fry in a heartbeat!
billyjack
billyjack
Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
Old 02-20-2006, 05:57 AM
kowell is on a distinguished road
Hi
Do you want the simple answer? .
The simple answer is YES you can do that.
then you have a spare secondary to use for whatever.
Kym
Old 02-20-2006, 08:44 AM
gar gar is offline
gar is on a distinguished road
060220-0942 EST USA
Gads:
If both secondaries are of the same voltage and are wound with wire of the same size, then you can use one secondary at 1/2 the VA rating of the transformer.
Also being a toroid has nothing to do with the answer.
