Hi All, I am using a DC drive which takes analog tacho signals to run a Fanuc DC Motor which only have a Digital Encoder , so I need to convert the Encoder signals to Analog voltage to use this as Tacho feedback. Can anybody help me by suggesting a simple circuit? Regards Babar |
| Are you using later type Drives? As modern ones run a DC motor in the torque mode, so the tach can be eliminated. If you really need a tach, there are several simple dedicated IC's that will produce digital to analogue signal ones I have used in the past is the National LM2907 the IC manufacturers have application sheets on their sites. You will only need to use one of the encoder channels i.e. A or B. Of course, you will also need the encoder for feedback in a CNC system. Al.
Your right of course, I fired this off in a hurry this morning, and realised it when thinking of it later.It requires it more sophisticated DtoA than the national IC. I think I have the circuit somewhere , I will try and dig it out tonight. Al.
| ACtually this is the main problem , to get the -ve sign. For this I need to have a circuit which can convert the Quadrature Encoder signals to the step and Dir signals , then the Dir signal can be used for changing the sign of the analog output voltage. For Quadrature Encoder to the step and Dir signals I tried the cicuit attached , but it didnot worked, I am getting pulses on the Dir output instead of getting high or low signals.... |
