Old 09-19-2003, 01:40 AM
samualt is on a distinguished road
What power supply do I need?
I have 3 servo motors with the following characteristics:
Reliance Electric DC Brushed Servo Motors, Model E712
37.51 Oz-In/A
25.0-30.5 V/KRpm
Motor Terminal Resistance .75-1.02 Ohms @ 4A.
Maximum Terminal Voltage 60V
Maximum Continuous Speed 2100 RPM (No Load)
Maximum Peak Torque 1500 Oz-In.
Maximum Peak Current 44.5A
Maximum Continuous Stall Torque At Max Motor Temp 300 Oz-In.
Maximum Continuous Current 8.9A
So, what kind of power supply from hell do I need to build? I was thinking about using toroid transformers.
I assume that I want a power supply that puts out about 55V at many amps.
I know a little electronics but I'm not used to building power supplies this big.
Anyway, what would you suggest?
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 10:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 04:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 10:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 11:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 11:36 PM
