Old 01-27-2006, 02:05 PM
DaPyro is on a distinguished road
Breakout boards
I want to know if any of the more experienced cnc users can help me out. I am planning on building a 3 axis cnc router machine. Later on I would like to build a 4th axis attachment. I will have a travel of 3’ X 4’ X 8”. I want to be able to mill aluminum and mdf. I will have a coolant system for the aluminum and a dust collector for the mdf g-code selectable. I want to use servo motors for a closed loop system I would like to incorporate an automatic tool changer g-code selectable. I think I can design a tool changer with one or two i/o’s. I would like a VFD spindle. But am willing to use a regular router spindle. I am all new to cnc machining. If there is any recommendation I am willing to listen to them. Like I said I am all new to this so help me out. Here are a few break-out boards I was thinking on using. Let me know if I should look at any more? Thanks for the help! I will post pictures as the project progresses.
www.CampBellDesigns.com Combo break-out board: $245.00 USA
The purpose of the Combo board is to interface the PC parallel port to the Gecko stepper motor drives and to control four relays for powering on aux devices such as spindle, vacuum pump, and coolant pump from 115VAC. The combo board also includes the spindle speed function that can control a variable frequency drive (VFD) through an optically isolated 0~5 VDC or 0~10 VDC. The Combo board also has an output for one Quadrature encoder that can be used for a manual pulse generator (MPG).
Website http://www.campbelldesigns.com/Combo-board.php
www.Rutet.com Motherboard R990mb: $116.00
The R990mb is an interface, which simplifies interconnection between PC running Step & Direction CNC software via LPT (printer) port and the physical CNC hardware such as motor drivers, cooling pump etc. It can be used with up to four R990/R990H/R90H/R991H/R992H servo drivers and R990io relay board. The R990mb has direct interface to PC printer port (DB25 - LPT port) and DB15 for connecting the limit switches.
Website http://www.rutex.com/home/index
www.rogersmachine.net Sound Logic Encoder Interface: $136.50
Closed Loop performance for all Mach2/3/4 software’s
4 Input/Output connections for Gecko drives
Works with Stepper systems w/encoders also
4 multi-purpose inputs for MPG's, probes, etc.
4 on-board relays controlled by M-codes in the software rated 125
VAC and 15 amps. Coupled with Breakout board, provides 8 outputs
in total.
Alerts the operator of positioning errors on each axis.
Provides External 5 volt supply for encoders.
Provides DRO position of all axises when Mach is in "Reset" for
manual machining.
Works with 2nd parallel port card which can be purchased here and
included with interface.
Cable for 26 pin connector to DB-25 included.
Fast, easy installation and software configuration.
All setup instructions outlined in PDF manual on "download" page.
On a 3 axis system, the 4th axis may be used for an MPG input.
Tracks the .001" startup crawl of each axis and allows the user to
resync this to the machine position. Without the interface, this is
usually not noticed when axis motors are powered up.
Website http://www.rogersmachine.net/encoderinterface.html
Old 01-27-2006, 02:52 PM
RTP_Burnsville is on a distinguished road
If you would like to build your own check out www.pminmo.com. I just received some blank PCB's from Phil and they look nice for about $10.00. His interface board will connect your PC parallel port to a three axis setup.
Robert
Old 01-27-2006, 04:14 PM
pminmo's Avatar
pminmo is on a distinguished road
RTP,
4 axis.. I'm working on a webpage to show how to make it work with geckos and other drives, using a different style connector. In the left picture there are 3 cables constructed of the 4 axis. The black wires are direction, green step, blue 5V. Should make a pretty clean layout. You still need an isolated 5V source.
Phil
ID:	14241   Click image for larger version
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 01-27-2006, 04:32 PM
Moderator
JerryFlyGuy is on a distinguished road
Another Board set is CNC4PC.com, I haven't purchased anyof their boards, but would also like to hear what others have to say
Old 01-28-2006, 07:46 AM
Sorry Phil, I forgot about the fourth axis as I only plan to use three in my setup at this time.
Old 01-28-2006, 10:54 AM
pminmo's Avatar
RTP,
Not a problem, just wanted to clarify.
Old 02-03-2006, 10:58 AM
jasonmarkham is on a distinguished road
hi,
i build my own board . took the parallel port and buffered it with a 74hc541 then to a darlington driver. all inputs 5 and outputs 8 are opto isolated .. works very good for me..
You will find the pics in my gallery .
also i used a standard atx psu and build a breakout psu board too, with soft on power switch ..
Old 02-03-2006, 11:23 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
A few other boards and approaches to consider. Those breakouts are good for the axes, also consider for axes and stepper driving:
- PMDX: http://www.pmdx.com/
and, one that not too many probably are thinking hard about yet:
- GRex: http://www.geckodrive.com/
Good Mach support for GRex is probably several months (perhaps as much as 6 months) away, but once it is done, this will be quite a device for those with lots of axes and lots of inputs and outputs. It handles 6 axes, 6 encoders, 16 outputs, 22 inputs, 4 analog ins, 4 analog outs, and a partridge in a pear tree! It gets around the limitations of parallel ports via a LAN or USB connection. It doesn't really cost any more than these other solutions either.
In terms of needing more I/O lines for encoders, control panels, or non-axis driving uses, you should take a look at:
- ModIO: http://www.homanndesigns.com/
ModIO is a serial port board that is cost effective and can support 8 inputs, 8 outputs (can cannibalize some of these for 2 encoders or MPG's if needed), 3 analalog inputs, and an LCD interface. It makes an ideal board for pendants as one example.
Best,
BW
Old 03-05-2006, 05:44 PM
bret4 is on a distinguished road
One more board is sold at. http://www.candcnc.com/
Bret
Old 03-19-2006, 08:02 PM
dgalaxy is on a distinguished road
has any one used the candcnc breakout board are you guys happy with it
Old 03-19-2006, 11:49 PM
Gold Member
mlaws1172 is on a distinguished road
I just put togethor a setup for another CNCer. He bought candcnc boards. They are first rate and you can't beat the support.
mike
  #12   Ban this user!
Old 03-21-2006, 10:43 AM
thanks for the reply
