| Hi Evan, I think that switching refers to the method of rectification of the AC supply to make DC. Somehow, the power supply outputs a series of pulses that simulate a DC current. The waveform is not dead smooth like true DC, but is chopped. A PWM amplifier runs on this chopped DC, I believe. If you go for a real DC power supply to feed your amplifiers, you will get around the choppy DC problem. I believe that the motor needs to possess a certain amount of inductance to smooth over the jaggedness of the "switched power" supply. Motors will typically have a rating in millihenrys or microhenrys that give you a ballpark figure to compare with the specs of the motor load recommended for a given power supply. Balsaman might know more about this stuff
| As far as I know Hu is correct. A switching supply often doesn't use a transformer. PC supplies are switching supplies. There are filters and such to smooth the DC tho and to my knowledge a switching supply works fine for steppers and such. Perhaps the performance is not optimal, I am no expert on the subject. I used a PC supply on my first router with great success, as have many others. Eric
__________________ I wish it wouldn't crash. |
| Switching power supplies rectify the AC line voltage and filter it at about 320VDC (voltage doubler rectifier). This DC voltge supplies a pulse-width regulator that operates at 40 to 100kHz. The high frequency is passed thru a transformer and is rectified back into a DC voltage. Why do all that? Transformers are much much smaller at high frequencies and the pulse-width "switcher" regulates the output voltage without generating heat the way a linear regulator does. The result is a small and light power supply, often less than 10% the size of an "iron" power supply (xformer, rectifier, filter cap). If a linear voltage regulator is used with the "iron" supply then the heat generated can be enormous, a problem the "switcher" doesn't have. Mariss |
| How does a power supply work. | ynneb | DIY-CNC Router Table Machines | 1 | 07-27-2011 10:40 AM |
| Diy Power Supply Choices | berin | DIY-CNC Router Table Machines | 11 | 07-13-2005 04:47 PM |
| 5 Volt Power Supply Tripping | murphy625 | General Electronics Discussion | 13 | 02-27-2005 10:05 PM |
| Is this power supply rating adequate? | jerryrigge | General Electronics Discussion | 3 | 11-25-2004 11:06 AM |
| Choosing a Power Supply for Retrofit? | pfeist | General Metal Working Machines | 4 | 05-23-2004 11:36 PM |
