Results 1 to 4 of 4
Thread: Boost PC ATX Power Supplies to 24v..32v
    ggg
    ggg is offline
    Registered ggg's Avatar
    Jul 2005
    Argentina
    Exclamation Boost PC ATX Power Supplies to 24v..32v
    As everybody knows, PC PSU has many advantages: high current, low wheigh, small size, shortcut protection, +5v TTL & CMOS compatible, etc, etc... but specially that SMPS for PCs are really cheap.
    But the only problem is the low voltage to get a good result for yours Stepper Motors.
    Well.... Could all "The Experts" help me?
    Could you suggest some solutions
    I'm trying to find a solution for that problem.
    I want to try this:
    ATX PSU with 450W:
    +12v*18A
    +5v*45A
    I step-up them with 2 "MC34063A + IRFZ44" boards (few bucks),
    getting 24V*8A and all the advantages of a ATX PSU.
    Please take a look and tell me what you think.
    Attached Thumbnails Attached Thumbnails Boost PC ATX Power Supplies to 24v..32v-nuevo-1.jpg   Boost PC ATX Power Supplies to 24v..32v-nuevo-2.jpg
    _____________________________________________
    [COLOR=DarkOrange]Hare Krishna Hare Rama[/COLOR]
    ggg
    ggg is offline
    Jul 2005
    Argentina
    We can increase the power connecting them in parallel more PSU and changing the mosfet. Do you Know a simpler way?
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    Its been discussed several times, do a search and you will find them, Anyway I have three connected in series with a floating ground and get 32.6v 8a.
    Joe
    ggg
    ggg is offline
    Jul 2005
    Argentina
    You are right, There is many Thread on how to connect PSU in series (I did not try them), but this one is aim to get the best efficiency for a single PSU. and preserve the advantages:
    With 3 PSU you get 256W, with step-up or boost way you can get 196W for 1 PSU
    Do you lose the shortcut protection advantage with Series connection?, means extra disadvantage for series connection on SMPS.
    Also, you have to cut/break the Ground protection (3rd prong), so your PSU system will become unsafe, what’s more, dangerous.
