Old 12-28-2005, 04:33 PM
SPEEDRE is on a distinguished road
E-Stop Questions
I have Gecko 201's and plan to pass them through a cnc4pc breakout board to which I will also run my limit switch. So, I want to wire in an E-Stop button, well I bought a 22mm single contact block switch. As it came in two bags I assembled the switch the way I thought it should go together, as a dry fit. Everytime I push the button it falls apart,is that supposed to happen? If so, and I wire it to the breakout board, do I have to dissmantle my enclosures and reassemble the switch in the event of an emergancy shut off?
