Results 1 to 9 of 9
Thread: Will This drive work with Bipolar Motors?
    Nov 2011
    Registered doorknob's Avatar
    Jan 2010
    The CSD-series drivers are shown in combination with stepper motors in the catalog pages of this document (an Oriental Motor catalog chapter):
    http://www.promotion-ie.de/downloads...e_2-Phasen.pdf
    The wiring diagram on page B-190 shows a 6-wire motor hooked up to the driver. So, unless I have missed something important, my best guess is that the driver is not compatible with a 4-wire bipolar motor.
    Nov 2011
    After doing some research about the operation of stepper motors
    How Stepper Motors Work
    I think if I connected +A lead of the stepper motor to the driver and the A- to the other two open slots on the board and the same for the B side, it might work but I wouldn't be able to energize half of the motors coils. Maybe I'm overlooking a problem but the animation helps to understand. Could someone give me some incite?
    Nov 2011
    Like this:
    Attached Thumbnails Attached Thumbnails Will This drive work with Bipolar Motors?-stepper_coil_diagram.jpg
    Jan 2010
    I don't see how that could work.
    You would be effectively shorting out half of a unipolar driver with that connection.
    Nov 2011
    Quote Originally Posted by doorknob View Post
    I see it would only work running in one direction, that sucks I'll have to get 6 wire steppers if I want to use them. How do the drivers compare with geckos?
    Jan 2010
    Those drivers do not look like they are very sophisticated - for example, they only offer the choice of full steps or half steps, but no microstepping.
    Oct 2004
    From what I can see from the data sheet for that driver you can wire a 4-wire motor to it. It appears that the terminals on the driver board for the motor input are labeled with colors. Red/Blue will be one phase and Black/Green will be the other phase. Don't connect anything to the Yellow/White terminals. If the terminals are labeled with numbers it appears the 1/2 will be one phase and 3/4 will be the other phase. Don't connect anything to the 5/6 terminals.
    Chris
    Oct 2004
    Quote Originally Posted by flojor10 View Post
    If you're serious about cnc get the Gecko G540. It's an entirely different class of product and a worthwhile investment.
    Chris
    1. Can I use these motors as bipolar?
      By Walky in forum Stepper Motors and Drives
      Last Post: 08-16-2011, 04:20 PM
    2. Will this bipolar design work???
      By 666 in forum Open Source Controller Boards
      Last Post: 03-19-2011, 11:17 AM
    3. Gearing the bipolar motors, less RPM = better?
      By Witsenburg in forum Stepper Motors and Drives
      Last Post: 01-23-2008, 10:11 PM
    4. bipolar/unipolar motors
      By studysession in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-17-2007, 02:50 PM
    5. Bipolar from unipolar motors
      By MrWild in forum Stepper Motors and Drives
      Last Post: 05-13-2006, 11:56 AM
