Old 12-22-2005, 04:46 PM
Minesgeek is on a distinguished road
Question Power supply design
Hello,
I'm a college student trying to get into cnc machining. So, to save cash for software I'm going to build my own power supply and drivers for the steppers. I have done a lot of research but there are a few things I need clarified. Here are the specs for the equipment I have or plan to use:
Taig Mill (cutting anything from plastic to steel)
3X Bipolar 276 oz-in steppers: Rated 4.5 volts, 2.8A/phase
3X L6208 Bipolar stepper IC: 8-52V input, 60V peak; 2.8A RMS output, 5.6A peak
At the moment those are my only design considerations. I believe the steppers are a little overkill for my mill, so I'm currently assuming that running at only 10x voltage and current limiting to ~1.5 Amps will work fine. Here are my questions:
Stepper motors are rated 2.8A/phase, could someone explain the /phase?
Should the power supply be regulated and what constant current should it be able to handle?
I'm primarily concerned with the /phase rating and the stepper requirements and how it effects power supply requirements. Any other suggestions would be much appreciated though!
Thanks!
Old 12-22-2005, 06:08 PM
ViperTX is on a distinguished road
With steppers you have to energize 2 phases at a time, a phase is basically a winding.
2 phases x 2.8 amps/phase x 3 steppers x 2/3 = minimum current rating of power supply (about 12 amps). It does not require regulation.
Old 12-22-2005, 06:53 PM
pminmo's Avatar
pminmo is on a distinguished road
Minesgeek,
You might find some help pn my power supply webpage: http://pminmo.com/simpleps.htm
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 12-23-2005, 01:30 AM
jlcortes is on a distinguished road
power supply???
I have a power supply design for your aplication! It is a bit bigger than you expect hehehe.
It could be interesting for powerfull 48v DC servo aplications,
It is a two-transistors forward converter with 4000W (based on a inverter welder) it is based on common current mode switch-mode powersupply controlled called UC3845.
I started to draw a clear schematic but it is incomplete. I have a prototype working and i can get any information.
Jose Luis.
ID:	13126   Click image for larger version
ID:	13127   Click image for larger version
ID:	13128   Click image for larger version
Old 12-23-2005, 08:04 PM
Talking
ViperTX,
Thanks for the explanation, that was what I expected but I couldn't find a good description.
pminmo,
Thanks for the site, I have built a few power supplies using similar designs in my electronics courses. I'll check out the site a bit further.
jlcortes,
That design looks interesting, if you finish a schematic I would really like to check it out. I'll send you a pm with my email on it if don't mind sending the schematic to me.
Nick,
Old 12-29-2005, 04:31 PM
ggg's Avatar
ggg ggg is offline
ggg is on a distinguished road
What about this?
Boost PC ATX Power Supplies to 24v..32v
_____________________________________________
Hare Krishna Hare Rama
