With steppers, you really only need two switches per axis, assuming you've slaved one of the steppers on your Y-axis to the other. Servos, depending on how they've been set up, are a different story.
Mark
I hope this question is understandable, if so and someone can answer it for me, Thank you very much. Your help and knowledge is always greatly appreciated.
Craig.
I am in the process of wiring limit switches and I have 2 on the Z-Axis as well as on the X-Axis.
The machine I have built has 2 stepper motors that drive the gantry along the Y-Axis, do I need only 2 switches on the Y-Axis 1 at the positive and 1 at the negative ends of travel or do I need 4, 2 at positive and 2 at negative?
To connect the wires for the limit switches to the breakout board terminals would I connect them using this example:
The + and- designates positive or negative travel of the designated axis, NOT THE POWER SOURCE.
+Z-Axis Red wire to terminal 10
+Z-Axis Black wire to terminal 5v
-Z-Axis Red wire to terminal 10
-Z-Axis Black wire to terminal 5v
+X-Axis Red wire to terminal 11
+X-Axis Black wire to terminal 5v
-X-Axis Red wire to terminal 11
-X-Axis Black wire to terminal 5v
+Y-Axis Red wire to terminal 12
+Y-Axis Black wire to terminal 5v
-Y-Axis Red wire to terminal 12
-Y-Axis Black wire to terminal 5v
If wiring 4 limit switches are needed on the Y-Axis would it be like this?
Left+Y-Axis Red wire to terminal 12
Left+Y-Axis Black wire to terminal 5v
Left-Y-Axis Red wire to terminal 12
Left-Y-Axis Black wire to terminal 5v
Right+Y-Axis Red wire to terminal 13
Right+Y-Axis Black wire to terminal 5v
Right-Y-Axis Red wire to terminal 13
Right-Y-Axis Black wire to terminal 5v
Mark
Mark (wendtmk)
Thank you for your help and response.
Craig
Craig,
You're very much welcome.
Mark
If your using Mach3, and want the slaved motors to "auto square" the gantry while homing, you'll need two switches on the Y axis at the Home end.
