Results 1 to 5 of 5
Thread: Vacuum pump wiring
    Mar 2008
    canada
    Vacuum pump wiring
    Hello all,
    The morbidelli U46 has come to the point of wiring up the vacuum table and all controls included. I have collected the majority of parts needed...that I know of...and sent a rough diagram of what I am doing to get some feedback on what I missed or what I should also include for ease of use. If the electrical experienced out there can give me a little help it would be much appreciated.
    Im not to sure how the push button switches work and what type I should use for this application.
    Wade
    Attached Files Attached Files
    May 2012
    Finland
    Vacuum Pump control wiring
    Here you have, i drew the wiring for you.
    Before motor contactor you can add an overcurrent protector
    ( autofuse or 3 pcs fuses ) if needed. Fuse current about 2.5 x motor nominal current.
    Regards
    KAK
    Vacuum Pump control_01.pdf
    Vacuum Pump control_02.pdf
    Jan 2006
    Wade
    As stated, you need some overcurrent protection somewhere. I would recommend a thermal overload relay in additon to your magnetic contactor.
    Also, why do you have a relay switching a relay? Just go straight from your pushbutton to the magnetic contactor.
    Matt
    Mar 2008
    canada
    Thank you very much kak111. That helps me out a lot. I'm going to go over it in detail tonight.
    The reason I want to go with a double relay system is that the vacuum pump is going to be farther from the router than the main cabinet, and I thought running low voltage to a relay in the vacuum pump enclosure would be better since I have 220 in the vacuum pump enclosure all ready.If this is not the way it is done let me know, I want the electrical to be up to standards for safety of the users and the equipment.
    When I order the switches what do I ask for? An illuminated green, on/off locking 24volt pushbutton? Does it have to be NO and only single pole?
    Wade
    May 2012
    Finland
    In Vacuum Pump control_01.pdf is more electrically safe low voltage 24Vdc control circuit
    ( isolated from the mains voltage )
    in this wiring.....
    An illuminated green, on/off locking pushbutton
    latching (push on – push off)
    Lamp voltage 24Vdc
    Switch contacts 125Vdc or higher / 1A or higher
    In Vacuum Pump control_02.pdf is direct 220V line voltage control circuit.
    in this wiring....
    Lamp voltage 220Vac
    Switch contacts 250Vac or higher / 1A or higher
    KAK
    1. Vacuum table and vacuum pump
      By garagefela in forum DIY CNC Router Table Machines
      Last Post: 01-25-2012, 11:30 AM
    2. V8 vacuum pump?
      By diyengineer in forum Work Fixtures and Hold-Down Solutions
      Last Post: 11-06-2011, 09:54 PM
    3. Vacuum Pump
      By ranchak in forum Moldmaking
      Last Post: 10-26-2009, 01:13 PM
    4. Need Help!- Vacuum Pump
      By jfcamilo in forum DIY CNC Router Table Machines
      Last Post: 04-29-2008, 04:45 PM
    5. Where to get a vacuum pump
      By whiteriver in forum DIY CNC Router Table Machines
      Last Post: 05-11-2004, 11:47 AM
