Results 1 to 3 of 3
Thread: Is shielded cable required for stepper motors?
    Jun 2005
    I am building a 5' x 10' plasma table with large Nema 23 stepper motors. Should i use shielded cable to the motors? Has anyone had any issues with using unshielded?
    Oct 2005
    The motors and their drivers do not normally require shielded wire. However the motor wires can generate some electromagnetic noise so if sensor wires are run next to motor wires the sensors may pickup some noise.
    I used unshielded wires on my machine on 2 motors and shielded wire on the other motor, not for any particular reason it was just the wire I had.
    If you are purchasing multicore wire, or if you will have sensor wires running near motor wires it's just as easy to buy shielded multicore wire.
    Registered bobsch's Avatar
    Oct 2008
    Required? No, but using shielded cable will reduce the chance of interference. Since interference problems can be some of the hardest to troubleshoot and shielded cable not that much more expensive than unshielded, I'd use it.
    JMHO
    Bob
    "Bad decisions make good stories."
  1. Stepper motors or servo required?
    By vwdevotee in forum Stepper Motors and Drives
    Last Post: 06-21-2010, 04:39 PM
  2. Shielded versus not shielded cable.....?
    By REVCAM_Bob in forum General Electronics Discussion
    Last Post: 05-23-2007, 08:55 AM
  3. Shielded cable help please.
    By Oldmanandhistoy in forum General Electronics Discussion
    Last Post: 04-02-2007, 08:05 AM
  4. Shielded Cable
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 06-13-2006, 11:00 PM
  5. Using Cat 5 cable for stepper motors?
    By 10bulls in forum General Electronics Discussion
    Last Post: 04-23-2005, 11:24 PM
