I got the instruction from www.pminmo.com on this 3axis board. Has anyone built a similar one ? Here's my setup: This is the author's: But my problem is the board doesn't seem to control the motors, its dead. I need help troubleshooting. |
| Hmmm, I don't see the 'power' resistor and I don't see any power supply line going to the stepper common connection. IIRC, the driver board is to be used with 5/6 wires unipolar stepper motor.
__________________ Stupid questions make me smarter... See how smart I've become at www.9w2bsr.com ;-P |
Current Limiting Resistors (IMPORTANT) Anytime a power supply for the stepper motor is used that is greater than the rated voltage of the motor, current limiting resistors are required. This board does not contain room for current limiting resistors as they can be quite large sometimes. Even if you're not using the limiting resistor, you still need to connect power to the stepper common wire. Looking at the datasheet, it appears that the stepper has 5 solder point but only 4 wires. May be it was driven bipolar by the original driver in the printer :frown: I'll be in the chat room for next few minutes...
| Beg to differ... the board is good simple design for starters. As with most DIY designs, the documentation is normally not up to the mark. Find the common wire or solder point on the stepper and you should be spinning with no problem
| lol so wait, connecting that to the board should supply the power to the motor as well. The only time when you need extra power to the motor is when you make 3 different boards for each motor connecting to the PC connector piece. Then you would need the power wires to jump. THis board eliminate all that. |
| Hope the image make some sense... The ABCD connections are on your board, i.e., the 4 wires from your stepper. The + connection goes to your power supply (off board).
#10
| The solder points I referred to earlier... thus (may be) eliminating the 'operation'. BTW, it is highly NOT recommended to dissassemble any stepper motor for several reasons... You got a multimeter handy somewhere? If yes, measure the resistance between the solder points and let us have the readings... Also take note to which solder point are the wires attached.
__________________ Stupid questions make me smarter... See how smart I've become at www.9w2bsr.com ;-P Last edited by abasir; 11-30-2005 at 01:50 AM. |
#12
| venomx999, Your photos seem to be kinda out of focus, but it looks like there is a 5th and maybe a 6th terminal not in use. I would suspect that these would be the center-tap if used as a unipolar motor. I would not be surprised if the motor is in fact a 5 or 6 terminal motor, but only 4 have wires. This would be the case if the previous use for the motor required a bi-polar motor. The previous user might not have wanted an extra wire just hanging there. If possible, measure the resistance from terminal to terminal, as previously suggested. Dave
__________________ Any good electronics tech knows that 1+1=10. Just my 2.5 cents. |
