| Can you identify this driver? Hi, A guy called me to get his cnc lathe working. It's a retrofit. He got no paperwork with it at all. It has a driver board in it that runs two Bipolar steppers, one for x and one for z. It's a parallel interface. No matter what I tried I couldn't get the axis' to move. The chips that are connected to the parallel port pins are some sort of programable i/o chip. A search on google came up with nothing. The driver is made by a company called "Micro Systems Research" made in 1990, and the board is called "Optidriver". I am not even sure if it works on step/dir or some kind or poropitary software or what. I will probably replace it with a Xylotex board, but I thought I would try here first. Eric
__________________ I wish it wouldn't crash. |
| Eric, Does the lathe spindle have an encoder? If it doesn't you might consider one so it could be used with TurboCnc. Outside of identifying and testing the chips and drivers it might be simpler to just replace the board. Does it have a good power supply? Chris |
| No spindle encoder. Its a wood lathe. I plan on using turbocnc. I tried identifying the chips but as I said they are the programmable variety, so who knows what they do in the circuit. It has a good powersupply but it's 40 volts, so I would need to replace that with a 24 volt supply. Eric
| Yes seen that encoder. The guy is going to use it for stair spindles. Eric
| Looks like it got taken on by MicroKinetics. No longer listed, but there's a picture of it here : http://www.microkinetics.com/stepmd.htm I'm sure their technical support would help. Richard |
| OPTIDRIVER 2-AXIS MOTOR DRIVER HI BALSAMAN. I FOUND A 1999 CATALOG WHICH HAS A SCHEMATIC OF A SIMILAR DRIVER. IT SEEMS THAT PINS 9 &10 (ON THE DB-25 CONNECTOR) HAVE SOMETHING TO DO WITH ENABLING THAT DRIVER. YOU SHOULD TRY GROUNDING ONE OR BOTH OF THOSE PINS. GOOD LUCK! LEN |
| I found Microkinetics. Thanks for all who replied. They sent me a manual for the board. The guy who's lathe is comes from also ordered thier controller that fits in the computer and the gcode software they sell, so we are all set! Thanks everyone! Eric
| PIC Open source Servo Driver Schematics development? | Rossz | Open Source Controller Boards | 90 | 10-26-2011 04:37 PM |
| Good driver for Omron U75030VA-BS1 servomotor? | Vikketsi | Servo Motors and Drives | 2 | 02-26-2005 03:53 PM |
| servos motor controled by stepper motor driver? | mike10 | Servo Motors and Drives | 1 | 01-03-2005 06:05 PM |
| 4 Channel Stepper Driver Which One! | dewayne | General Electronics Discussion | 2 | 07-08-2004 10:47 PM |
| Fun with floppy stepper and driver | Konstantin | General Electronics Discussion | 5 | 03-08-2004 02:18 AM |
