Did you just replace the CRT only?
If so, before going any further I would either borrow a high voltage probe if you can find a TV shop that uses them any more or take it in to have the HV measured both when bright and dim, just to see if HV is the problem.
HV for a small crt can range from around 9kv to 12kv.
LinkBack URL
About LinkBacks
