Hello All, Need to connect relays,limited to 1 amp@48v.per channel. Can I use 1.3 amp@24v.relay? Am using 24Vpower supply, would this need a resistor,or? TIA Bear |
| I would assume that current is the rating of the contact, not the coil current. If you don't have the specs on the relay, for a DC type, just measure the resistance of the coil and use ohms law. Typically a small 24vdc relay coil current would be 20~80ma. Al.
| Thanks for reply Al Not sure what Im doing.The control box "note" says "limit1amp@48v." Im assuming I supply voltage to control box pin1,when program M3 is read,connects pin2 active makes circut.3/4,5/6,and so on (on control box, not computer pins)Has 4 connections,I believe optisolated.Am wondering(my relay reads 1.3@24v,am using 24 v.ac.from transformer) is thi sounding correct? TIA Bear |
| I would guess thats the contact rating, measure the resistance of the coil and divide it into 24 and this will give you the current of the coil. Al.
