Old 11-22-2005, 02:22 PM
*Registered*
SteveT44 is on a distinguished road
Current Regulated Bipolar Driver
I've been looking at the options for a current regulated (chopper design) bipolar driver that can handle more than 4 amps. The available options are in excess of $100 per axis. The other common method seems to be big power resistors inline with the stepper that to me would seem ungainly at higher amperages. Another option that doesn't get much mention on this forum is constant current power supply. It would be an easy matter to wire a LM138/338 5 amp voltage regulator as a current regulator and feed this output into any elcheapo bipolar driver. Has anybody done this?
Steve T.
Old 11-22-2005, 04:13 PM
Gold Member
CJL5585 is on a distinguished road
Current Regulation in Steppers Using LM138/338
Steve,
Haven't heard of anyone trying it, of course, I might have missed it if they did.
Question:
Since the different phases of a stepping motor are always changing polarity according to whether they are set up as full step, half step, or micro-step, how would you design for this factor in a current regulated stepper controller?
Jerry
Old 11-22-2005, 04:27 PM
*Registered*
Jerry,
The current regulated PS would feed a non-chopper single axis bipolar driver which controls your polarity switching. The power sequence would be main PS, current regulated PS, bipolar driver, stepper. There would be a separate current regulated/bipolar pair for each axis.
After further searching I've found OatleyElectronics.com is selling such a system in kit form, though limited to 2.5 amps. I've emailed them to see if their circuit can be boosted to higher amperage.
Steve
Old 11-22-2005, 04:34 PM
pminmo's Avatar
pminmo is on a distinguished road
I can't think of any real reason it can't be done. But at 4 amps your going to be pushed on max power dissipation vs power supply voltage. (after looking at the kit I suspect they are doing just that. 3 term adjustable regulators with a resistor to set current, major fan to dissipate heat). I've been toying with a design of a chopper adapter. But the drawing board is all the farther it has gotten.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 11-22-2005, 04:37 PM
eidos is on a distinguished road
hi steve
the regulation of the tide that flows in an electric wrapping
it is a very delicate matter.
in particular way when it comes tall amperages.
the solution more adopted and that to feed the motor, not with a tide constant, but with a tide to tall frequency and with very taller voltage generally of the value dc that the motor bears.
this way of piloting the motor is called chopped fashions.
or called more often PWM.
the method of the pwm is used, because feeding the motor to tall frequency, (20 khz-or +) the curve of couple becomes more linear and the motor to certain critical speeds doesn't lose power.
I have realized some drivers from up 10 ampers (RMS) up 150 voltses.
if they serve you I can realize you someone of it
look this link
some my board listed in ( the photos are visible only for registered user .. sorry )
http://www.computerup.it/forum/viewtopic.php?t=1490
look microstep curve
hi
my steppers turn to 17000 step/s, my stepper drivers arrive to more than 50000 step/ses :- (
Old 11-22-2005, 05:01 PM
Gold Member
Current limited MOSFETS
About 5 years ago, I designed a stepper interface that used International Rectifier Current limiting MOSFETS.
I don't remember what I did with the design since I did not build or test it, but I am almost certain it would work. You might want to look into this.
The MOSFETS could be purchased with current capabilities from 3 to 50 Amps if I remember correctly. I don't remember the part numbers.
Jerry
Old 11-22-2005, 08:13 PM
H500 is on a distinguished road
Steve, using a current regulator has no advantage over using resistors. In either case, a the same amount of power is wasted as heat.
Do you actually need such a large stepper? There are lots of people successfully using 2-3 amp motors.
Old 11-23-2005, 08:30 AM
*Registered*
Well I'm building a 50x50" router that I want to be able to mill 3/4" ply reasonably well. I'm looking at some 400 and 600oz bipolar steppers rated at 4 or 6 amps respectively.
Concerning the L297, how is the current sensing implemented with that chip? It appears to accept a 0 to 3volt range that would correspond to the current passing through the bridge it is controlling. Most designs use the complementary L298 dual bridge chip with the L297. There are many other full and half bridge modules available up to 40 amps or more with current sensing features. Has anybody experimented with alternative bridge modules with the L297?
Here's an interesting half bridge chip by Infineon.
http://www.infineon.com/upload/Docum...atasheet_1.pdf
Steve
Old 11-23-2005, 10:33 AM
*Registered*
ESjaavik is on a distinguished road
Originally Posted by eidos
look this link
hi
Hi Eidos,
I did register but still cannot see any pictures.
I must admit my Italian is not much to brag about, so I may have missed an important setting.
Regards
Einar
Old 11-23-2005, 10:54 AM
Gold Member
creative_mind is on a distinguished road
Regarding using the L297 to drive higher current bipolar stepper motors using transistors, here is something I picked up over the internet some time ago - note that the URL does not work.
Name:	bipolar stepper driver 1.jpg‎
ID:	12225   Click image for larger version
Name:	bipolar stepper driver 2.jpg‎
ID:	12226   Click image for larger version
Name:	bipolar stepper driver 3.jpg‎
ID:	12227   Click image for larger version
Name:	bipolar stepper driver 4.jpg‎
Name:	bipolar stepper driver 5.jpg‎
  #11   Ban this user!
Old 11-23-2005, 03:08 PM
h steve
look the
Over Voltage Lock Out ! only 30 volts max
Steve
  #12   Ban this user!
Old 11-23-2005, 03:30 PM
pminmo's Avatar
You can use a L297 to drive discrete components. Bipolar transistors are the simplest way to go, but will dissipate a fair amount of heat at high currents.
