Results 1 to 4 of 4
Thread: Basic Motor Wiring
    Mar 2012
    Basic Motor Wiring
    Hi All, First post here after just picking up a Logan 1875.
    The lathe had a 3-prong, 125V 15A twist lock plug. After changing that to a regular flat blade plug, the motor hums and barely turns, so it must have been wired for 220.
    The diagram on the motor says the following:
    Model HDN56MRC17F1O (made in China)
    Low Voltage:
    Yellow-White-Black -Line2
    Orange-P5-Red-INS
    T1-Blue-INS
    P1-Line1
    I'm confused because in the electric box, there are just two groups of 4 wires
    coming from the motor, 4 wires go to the reversing power switch, and I do not know what P1, P5, and T1 are. I assume "INS" means insulated...
    This seemingly trivial task is the next obstacle for me now. Thanks for any help here.
    Mar 2012
    Update
    Hi All, I just scrapped the idea of 110 and ran a 220 outlet. Seems risky to run just a neutral and two hots, but that's the way the dryer's always been...
    Now it's off to learning about the lathe.
    Dec 2003
    Dangerous without a Ground, you probabally had a 220 and ground, no neutral?
    Sounds like you were running a dryer with no ground also?
    Do you not have any history of the lathe at all?
    Mar 2012
    That's what I figured - dangerous...
    I bought two machines from an older gentleman - an Enco RF-30 Mill with x-y DRO and 3-axis power feeds, plus the Logan 1875, and a bunch of end mills and cutters. He had them outside in a make-shift shed and was letting them waste away.
    By "neutral" I presume you mean the return has to be insulated, and it is not. I found a 30+30 amp dedicated line that went to the air conditioner, which was fed with "romex" - although I'm not sure if the AC has some other ground.
    The panel is only about 25 feet away, so I can run a proper feed and get new plugs. Right now I just wanted to soak everything in ATF and get things moving around so I could get them cleaned up - I'm trying to avoid a tear down.
  1. Need Help!- Newbie questions: Need drivers? Basic Wiring?
    By AKMike in forum General Electronics Discussion
    Last Post: 02-22-2011, 12:24 AM
  2. Very Basic questions on Motor Control
    By canyon289 in forum DIY CNC Router Table Machines
    Last Post: 12-31-2010, 03:14 PM
  3. excellent basic motor info
    By Boltz in forum Servo Motors and Drives
    Last Post: 07-20-2010, 06:24 PM
  4. Fairly basic questions re stepper motor wiring!
    By HankMcSpank in forum Stepper Motors and Drives
    Last Post: 08-22-2008, 04:58 AM
  5. Basic Motor Voltage Question
    By pzzamakr1980 in forum General Electronics Discussion
    Last Post: 05-03-2008, 02:26 PM
