Results 1 to 2 of 2
Thread: Magneto ignition thoughts and questions
    Oct 2005
    My curiosity was aroused when someone on a bike forum hosed magneto ignitions. Without getting into the arguments for or against, I'm wondering how a person might add a points-less module that offers advance(retard) timing for the spark. If an ATmini could do the brain work, a ring of very small magnets added to the rotor could excite a small coil to power it.
    This is brain storming the possibilities. An encoder measures speed and TDC, and the microcomputer plots the advance curve to engine speed. Any thoughts?
    Feb 2009
    Like a megajolt system?
    Doable for sure on even more of a DIY system, you could add a map sensor so you could adjust timing for engine load as well. My dirt bike uses a mag sensor with an electronic unit and coil. No points on any bike I've owned in the last 20 or more years.
  1. pilot arc ignition problem
    By twitte in forum General CNC Plasma And Oxy Fuel Cutting Machines
    Last Post: 12-11-2012, 01:42 PM
  2. Think im going to get a X4... any thoughts?
    By simila95 in forum Benchtop Machines
    Last Post: 04-16-2009, 11:16 AM
  3. New CNC router build -- thoughts, comments, questions...
    By twry84 in forum DIY CNC Router Table Machines
    Last Post: 02-23-2009, 05:14 PM
  4. Industrial engine ignition cut
    By itsme in forum General Electronics Discussion
    Last Post: 02-07-2006, 06:41 PM
  5. How to sheild a HF arc ignition cutter?
    By chinamill5 in forum General Waterjet
    Last Post: 12-04-2005, 10:24 PM
